skippyboyo1 Posted July 10, 2012 Share Posted July 10, 2012 Guys i have a 93 supra and need to no the clock size that fits in the dash pannel as standard, im looking to replace it with a gauge, the car is in a lock up at the moment so i cant measure it! Can you help? Thanks in advance Craig Quote Link to comment Share on other sites More sharing options...
shaky Posted July 10, 2012 Share Posted July 10, 2012 52mm Quote Link to comment Share on other sites More sharing options...
Littler Posted July 10, 2012 Share Posted July 10, 2012 As above 52mm gauges fit spot on Quote Link to comment Share on other sites More sharing options...
listy Posted July 10, 2012 Share Posted July 10, 2012 As above. However if the gauge is a little bigger, it's a 5 minute job with a file mate. That's what I did. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 10, 2012 Author Share Posted July 10, 2012 Guys that's wicked..... Thanks!!!! Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 11, 2012 Author Share Posted July 11, 2012 Just to continue on from this I'm wanting to fit a vault gauge to te 52mm home where the clock fits, where have people wired these up to? I've read wiring it from the existing clock wiring is wrong and to take it from the cig lighter. The gauge I'm fitting as stated iis a vault gauge and it also lights up. Any help would be fab or any links showing what others have done wound be brilliant Thanks Quote Link to comment Share on other sites More sharing options...
listy Posted July 11, 2012 Share Posted July 11, 2012 Wire it to the light for the cig lighter (the little grey plug) else the light will constantly be on. This way the light will only be on when the lights are on but will still work when not on iirc Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 11, 2012 Author Share Posted July 11, 2012 Wire it to the light for the cig lighter (the little grey plug) else the light will constantly be on. This way the light will only be on when the lights are on but will still work when not on iirc Mint, thanks for yor help I'll give it a try Quote Link to comment Share on other sites More sharing options...
