Car won't start.
SupraDan24
I jumped in the car Saturday morning to head up to Suprapod and the car randomly wouldn't start, i've never had an issue with it before. The engine will turn over no problem, it just wouldn't fire. The car was very low on fuel when i parked it up the night before, just a smidge above the empty mark, it was still running fine then. I have put 20L of fuel in it since then and it still wont fire. I have a few things to check tomorrow, i'm hoping someone could point me in the right direction.
1.) Which fuse is for the fuel pump, and where is it located? I checked quite a few under the bonnet that morning but they were all fine.
2.) If i have the ignition on, should the pump make any noise? It's completely silent at the moment.
3.) How do i check if the engine is getting fuel, can i just remove the fuel line in the engine bay and try starting the car and see if anything comes through?
I'm going to dig out my multimeter in the morning and check to see if the pump is getting power, that should rule out a blown fuse, then i'll try the things above.
I've just tried checking for Error Codes by bridging E1 and TE1 and the warning light doesn't even flash at all. I tried it with a paperclip and some wire, both times the light came on then went straight off. Does it matter that i dont have a Stock ECU? I have a Apexi Power FC ECU.
Nevermind, it's running now :) I have a fuse by itself next to the engin bay fuse box, when i tried to remove it, the connection at the bottom was broken in half :blink: New fuse and it fired straight away :)
Told you it was the fuel filter..!!:innocent:
