Urgent advice needed - supra only rev upto 4k
ray007
Update!!'. Tried using a manual ecu but no difference!!
Please help
Hi all
Really relying on you guys for some advice
Just installed a 2jzgte and w58 into a shell (also previously a GZ), and te car is only revving upto max around 4k rpm if revved gently, then kinda starts missing and feels like maybe a fuel cut or something?? If the throttle is pressed hard or blipped I get the same thing
Two things im concerned with is I believe the fuel return line is too small (didn't have originals) and there is a hks fcd pre-installed but not sure if on the correct setting and I don't have the manual.
Any advice would be much much appreciated, it's stopping me from getting ma project on the road.
Thanks in advance :-)
Edited by ray007
Update (see edit history)
Auto ECU? If so you're gonna have to look at the neutral/park start switch. If its not done properly you can get a false 4k rev ceiling.
*As it happens I have a manual ECU if you get stuck*
yup auto tt ecu, definately connected the 2 black & black/white wires on the gearbox plug thing, still haven't done the reverse switch tho, would that make a difference?
And your saying of the connection is weak I may get them symptoms?
Thanks a lot Craig I can always rely on you.
And would the manual ecu work fine with a tt?
Edited by ray007 (see edit history)
There's a certain way of doing the mod that removes the 4k safety rev limit. Yes it came from a manual 2jz gte car. That will remove all the auto conversion problems :)
well i havent heat shrinked yet but connections seem good
damn im kinda broke now but if you could pm me a price please
It'll never work right on an Auto ECU, don't bodge it, just get Swampys Manual ECU
I don't Believe that as I've had supra's converted before with auto ecu and manual gearbox including the 1jz engine removed from te soarer I bought from swampy :-)
A big thanks to 'Swampy' whos gone out of his way to help me out in this difficult time, has always given me loads of free advice and also let me have the manual ecu for peanuts to help me out..
Only if there were more people in the world like Craig (swampy) :-)
Thanks bud I owe you one
  • 2 weeks later...
