ray007 Posted July 9, 2012 Share Posted July 9, 2012 (edited) Update!!'. Tried using a manual ecu but no difference!! Please help Hi all Really relying on you guys for some advice Just installed a 2jzgte and w58 into a shell (also previously a GZ), and te car is only revving upto max around 4k rpm if revved gently, then kinda starts missing and feels like maybe a fuel cut or something?? If the throttle is pressed hard or blipped I get the same thing Two things im concerned with is I believe the fuel return line is too small (didn't have originals) and there is a hks fcd pre-installed but not sure if on the correct setting and I don't have the manual. Any advice would be much much appreciated, it's stopping me from getting ma project on the road. Thanks in advance :-) Edited July 23, 2012 by ray007 Update (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted July 9, 2012 Share Posted July 9, 2012 Fcd should be on 9 iirc. Other than that mate not sure Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 9, 2012 Share Posted July 9, 2012 Is it an ex auto or have an auto loom? Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 9, 2012 Author Share Posted July 9, 2012 Is it an ex auto or have an auto loom? Yes that's right an ex auto with auto loOm Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 9, 2012 Author Share Posted July 9, 2012 Fcd should be on 9 iirc. Other than that mate not sure In that case mine is on the correct setting Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 9, 2012 Share Posted July 9, 2012 Auto ECU? If so you're gonna have to look at the neutral/park start switch. If its not done properly you can get a false 4k rev ceiling. *As it happens I have a manual ECU if you get stuck* Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 9, 2012 Author Share Posted July 9, 2012 (edited) Auto ECU? If so you're gonna have to look at the neutral/park start switch. If its not done properly you can get a false 4k rev ceiling. *As it happens I have a manual ECU if you get stuck* yup auto tt ecu, definately connected the 2 black & black/white wires on the gearbox plug thing, still haven't done the reverse switch tho, would that make a difference? And your saying of the connection is weak I may get them symptoms? Thanks a lot Craig I can always rely on you. And would the manual ecu work fine with a tt? Edited July 9, 2012 by ray007 (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 9, 2012 Share Posted July 9, 2012 There's a certain way of doing the mod that removes the 4k safety rev limit. Yes it came from a manual 2jz gte car. That will remove all the auto conversion problems Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 9, 2012 Author Share Posted July 9, 2012 (edited) There's a certain way of doing the mod that removes the 4k safety rev limit. Yes it came from a manual 2jz gte car. That will remove all the auto conversion problems well i havent heat shrinked yet but connections seem good damn im kinda broke now but if you could pm me a price please Edited July 9, 2012 by ray007 (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 9, 2012 Share Posted July 9, 2012 Make me an offer? Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 11, 2012 Author Share Posted July 11, 2012 Man I can't work out this problem Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 11, 2012 Share Posted July 11, 2012 The solution is above, manual ECU Quote Link to comment Share on other sites More sharing options...
marc_p Posted July 11, 2012 Share Posted July 11, 2012 It'll never work right on an Auto ECU, don't bodge it, just get Swampys Manual ECU Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 11, 2012 Author Share Posted July 11, 2012 It'll never work right on an Auto ECU, don't bodge it, just get Swampys Manual ECU I don't Believe that as I've had supra's converted before with auto ecu and manual gearbox including the 1jz engine removed from te soarer I bought from swampy :-) Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 13, 2012 Author Share Posted July 13, 2012 A big thanks to 'Swampy' whos gone out of his way to help me out in this difficult time, has always given me loads of free advice and also let me have the manual ecu for peanuts to help me out.. Only if there were more people in the world like Craig (swampy) :-) Thanks bud I owe you one Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 13, 2012 Share Posted July 13, 2012 No probs mate, that's what it's all about if you ask me If you have any issues with it mate let me know. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted July 13, 2012 Share Posted July 13, 2012 great club this and people Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 23, 2012 Author Share Posted July 23, 2012 Hey all really stuck here I've now tried a manual ecu but it's made no difference at all!!!! Pleeeease help guys Quote Link to comment Share on other sites More sharing options...
