Few questions about syvecs s6
bigbloodyturbo
Just getting round to fitting my S6 as I've booked someone to map it this month. Main question is about the ecu working with an automatic, how hard is this and what needs to be done? Also does it use mostly stock sensors? I have the knock sensor and a map sensor but does it use OE oil pressure sensors etc?
It will need an oil pressure sensor fitting if you want to use that feature. The Syvecs will need to be hardwired in on an automatic, Ryan should be able to give you a wiring diagram for that.
