Supra N_A Posted July 4, 2012 Share Posted July 4, 2012 what injectors are needed for single build using the t61 turbo?? also what boost can the t61 take or what is known boost pressure for it?? Quote Link to comment Share on other sites More sharing options...
Geo Posted July 4, 2012 Share Posted July 4, 2012 i had drop in 800cc PE injectors dude on a stock fuel line, with a t67 non dbb and it was running 1.7 bar. Really depends on how far you want to take it the build, endless options and expensive ones Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 where can you get the 800cc injectors mate? price.. what they from? Quote Link to comment Share on other sites More sharing options...
Alex Posted July 4, 2012 Share Posted July 4, 2012 650's are enough. The 2JZ setup happens to have a rule of thumb that cc = hp so 650cc supports up to/around 650HP. It's fuel pressure dependent but ok for most uses. Injectors should be as small as possible without being maxed out beyond 80% duty cycles and full power. Keeping them small keeps means the fine control at idle/small throttle inputs is easier to achieve. I used 650cc drop in PE's on my T61. Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 can you link me up where you got them from mate?? so stock injectors are a big nope?? also what boost did you run on your t61? Quote Link to comment Share on other sites More sharing options...
Nic Posted July 4, 2012 Share Posted July 4, 2012 (edited) 650cc injectors would be big enough to support a T61, Power Enterprise injectors are a straight swap into the stock fuel rail. SH650A Power Enterprise 650cc High Impedence SH800A Power Enterprise 800cc High Impedence Edited July 4, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted July 4, 2012 Share Posted July 4, 2012 so stock injectors are a big nope?? also what boost did you run on your t61? The stock 440cc injectors will be maxed out at around 400hp, you'll need at least 650cc, 1.4bar should be safe to run on a daily basis, but I'd take advice from whoever is going to map the car. Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 cheers dude!! again thow just need to kno where i can get the 650s PE from cant find them anywere! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 4, 2012 Share Posted July 4, 2012 Here might be a good start http://www.power-enterprise.co.jp/USA/products/fuel/injector/index.htm Quote Link to comment Share on other sites More sharing options...
hodge Posted July 4, 2012 Share Posted July 4, 2012 What sort of management are you wanting to use to run them. If you go down the piggyback ECU route, (EMU, EMB, FIC) they struggle to control anything over 650cc and your idle will be horrendously lumpy. I had 800cc injectors in my blue supra ran by an EMU and the idle had me domented. Ryan did a great job on the map but the EMU just didn't have the facilities to control them precisely enough. Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 What sort of management are you wanting to use to run them. If you go down the piggyback ECU route, (EMU, EMB, FIC) they struggle to control anything over 650cc and your idle will be horrendously lumpy. I had 800cc injectors in my blue supra ran by an EMU and the idle had me domented. Ryan did a great job on the map but the EMU just didn't have the facilities to control them precisely enough. Was going to use the emu yes... Well what other solution is there of not using the emu?? Also 650 it will be so it's not over and you were using 800 so will explain idle issues??? Quote Link to comment Share on other sites More sharing options...
hodge Posted July 4, 2012 Share Posted July 4, 2012 Was going to use the emu yes... Well what other solution is there of not using the emu?? Also 650 it will be so it's not over and you were using 800 so will explain idle issues??? I don't really understand what you've said there dude. Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 I am on the iPhone lol.... Saying the reason you might of had lumpy idle is becouse you were using 800 injectors? But the 650 should be ok?? Where can I purchase these injectors from no where seems to sell them....Also where you using the t61 turbo mate? What boost and power did you make? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 4, 2012 Share Posted July 4, 2012 Once you're home, search a bit on the forum. You'll find a lot of info on this. Basically, a 60-61 mm turbo can push 500+ bhp at medium boost (1.4-1.5) on stock cams. Quote Link to comment Share on other sites More sharing options...
hodge Posted July 4, 2012 Share Posted July 4, 2012 I am on the iPhone lol.... Saying the reason you might of had lumpy idle is becouse you were using 800 injectors? But the 650 should be ok?? Where can I purchase these injectors from no where seems to sell them....Also where you using the t61 turbo mate? What boost and power did you make? Yeah the lumpy idle was because the EMU couldn't control the injectors correctly. Give Paul Whiffin a buzz. I'm sure he will be able to get whatever injectors you need bud. I had a GT45 turbo. Was huge, I was only running 0.8 bar. It mate just over 500hp. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 4, 2012 Share Posted July 4, 2012 What sort of management are you wanting to use to run them. If you go down the piggyback ECU route, (EMU, EMB, FIC) they struggle to control anything over 650cc and your idle will be horrendously lumpy. I had 800cc injectors in my blue supra ran by an EMU and the idle had me domented. Ryan did a great job on the map but the EMU just didn't have the facilities to control them precisely enough. Funny...Ian's runs spot on...not all injectors are equal... Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 4, 2012 Author Share Posted July 4, 2012 I used 650cc drop in PE's on my T61. ???????? where from Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 4, 2012 Share Posted July 4, 2012 Abit off topic guys - Is there any advantages off putting uk spec 550cc injectors or sard 650cc injectors into a bpu? Quote Link to comment Share on other sites More sharing options...
hodge Posted July 4, 2012 Share Posted July 4, 2012 Abit off topic guys - Is there any advantages off putting uk spec 550cc injectors or sard 650cc injectors into a bpu? It just means you can push your BPU power levels a little further safely with the 550cc injectors and a resistor pack. If you fit 650s you'll need some sort of management to control them. For a BPU car, 550cc injectors are way enough. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 4, 2012 Share Posted July 4, 2012 (edited) It just means you can push your BPU power levels a little further safely with the 550cc injectors and a resistor pack. If you fit 650s you'll need some sort of management to control them. For a BPU car, 550cc injectors are way enough. Thanks Hodge - I think that A98pmalcolm from the forum has sard 650cc injectors in his TT6. Just wondered if theres and advantage from stock 440's Edited July 4, 2012 by Chris Bailey (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2012 Share Posted July 4, 2012 Funny...Ian's runs spot on...not all injectors are equal... Agreed My idle sits at about 750rpm and it's a bit lumpy because of the cams, but certainly not because of the EMU. I run 720's but my static pressure is on the lowish side so they are pretty maxed out at 7200rpm @ 1.4bar on a T67. I could up the pressure and remap it, but then a) the fuel pump would probably run out of oomph and b) it runs fine as it is so why bother I think my injectors are RC Engineering, I got them 2nd hand and they are still going strong, despite running at 90 to 95% duty in the upper echelons. -Ian Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2012 Share Posted July 4, 2012 It just means you can push your BPU power levels a little further safely with the 550cc injectors and a resistor pack. If you fit 650s you'll need some sort of management to control them. For a BPU car, 550cc injectors are way enough. You need some sort of management to control the 550's as well, otherwise it'll overfuel by 25% and stall a lot Not much point unless you're running hybrids at 1.4bar really, then they become rather necessary. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 4, 2012 Share Posted July 4, 2012 (edited) ???????? where from Probably through Nic when he was a trader. I'm talking back in 2006... Why don't you mail them and ask them for a stockist.... [email protected] Edited July 4, 2012 by Alex (see edit history) Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted July 6, 2012 Author Share Posted July 6, 2012 will these work http://www.fuelinjectorclinic.com/cgi-local/commerce.cgi?preadd=action&key=IS145-0650 Quote Link to comment Share on other sites More sharing options...
Nic Posted July 6, 2012 Share Posted July 6, 2012 (edited) will these work http://www.fuelinjectorclinic.com/cgi-local/commerce.cgi?preadd=action&key=IS145-0650 They wouldn't fit the stock fuel rail - the stock injectors are side feed, high impedance - those are top feed, low impedance injectors, you'd also need to buy/fit an aftermarket fuel rail, fuel lines/fittings and resistor pack for them to work. Edited July 6, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
