fastcar Posted July 4, 2012 Author Share Posted July 4, 2012 1st turbo is online straight off the bat, and at around the 3500k the vsvs start building boost ready and at around 3800k the vsvs open giving full boost at 4k, not 5k first tubby is online straight away. its just the 2nd that is slow to come on. Mine is starting to come online at 4800rpm then on full boost at 5k Link to comment Share on other sites More sharing options...
supraGZaerotop Posted July 4, 2012 Share Posted July 4, 2012 sounds like somethings up there mate, i never had a problems with both of my TT boost wise,. most likely one of your vsvs is naft, wonder if a weak actuator could do this also,first tubby is online straight away. its just the 2nd that is slow to come on. Mine is starting to come online at 4800rpm then on full boost at 5k Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2012 Share Posted July 4, 2012 first tubby is online straight away. its just the 2nd that is slow to come on. Mine is starting to come online at 4800rpm then on full boost at 5k Have a look at the guide: http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Sounds like problem 3. Link to comment Share on other sites More sharing options...
sideexitsupra Posted July 4, 2012 Share Posted July 4, 2012 Have a look at the guide: http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Sounds like problem 3. Isn't that what I said in post 15? Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2012 Share Posted July 4, 2012 Isn't that what I said in post 15? Yes, and I checked that, you'd obviously read the guide But I was replying to fastcar who it seemed had not. Link to comment Share on other sites More sharing options...
fastcar Posted July 5, 2012 Author Share Posted July 5, 2012 Isn't that what I said in post 15? I did read your post and had a look at the manual and was going to have check on the 3 things you said Yes, and I checked that, you'd obviously read the guide But I was replying to fastcar who it seemed had not. Thanks that is a good right up and has helped me to understand the system a lot better hopefully I should have sorted out soon Link to comment Share on other sites More sharing options...
sideexitsupra Posted July 13, 2012 Share Posted July 13, 2012 My problem is solved. It looks like I may have been fiddling with the boost controller at some point and the gain was set at 20%. Now this has been adjusted back to zero it is coming on strong at 4000 apparently. Thanks to Whifbitz for sorting this once again Link to comment Share on other sites More sharing options...
fastcar Posted July 13, 2012 Author Share Posted July 13, 2012 My problem is solved. It looks like I may have been fiddling with the boost controller at some point and the gain was set at 20%. Now this has been adjusted back to zero it is coming on strong at 4000 apparently. Thanks to Whifbitz for sorting this once again could be worth me looking at this on my EBC. But then mine is turned off so not sure if that will efect it or not? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 13, 2012 Share Posted July 13, 2012 My problem is solved. It looks like I may have been fiddling with the boost controller at some point and the gain was set at 20%. Now this has been adjusted back to zero it is coming on strong at 4000 apparently. Thanks to Whifbitz for sorting this once again It was the other way round. Was on 5% and it's now on 20%. Boosting nice now anyway. Link to comment Share on other sites More sharing options...
sideexitsupra Posted July 13, 2012 Share Posted July 13, 2012 It was the other way round. Was on 5% and it's now on 20%. Boosting nice now anyway. Link to comment Share on other sites More sharing options...
Ian C Posted July 13, 2012 Share Posted July 13, 2012 could be worth me looking at this on my EBC. But then mine is turned off so not sure if that will efect it or not? If you have an EBC and it's turned off, your boost production will be slower as you'll suffer wastegate creep as boost rises. The installation of an EBC bypasses the stock VSV that stops boost pressure reaching the wastegate actuator until just before it's needed to limit boost. Link to comment Share on other sites More sharing options...
fastcar Posted July 14, 2012 Author Share Posted July 14, 2012 If you have an EBC and it's turned off, your boost production will be slower as you'll suffer wastegate creep as boost rises. The installation of an EBC bypasses the stock VSV that stops boost pressure reaching the wastegate actuator until just before it's needed to limit boost. So that's more then likely going to my problem I'm guessing. I did have turned on when I first went BPU but noticed that the RR was causing to much back pressure and holding the car back in the higher rev range. So I took the RR out out turned the EBC off. I will try turning it back on and have a play with the gain and see what happens. Thanks again again fellas Link to comment Share on other sites More sharing options...
