N/A - T is it worth it ? ? ?
Guest suprasteven
  • Replies 102
I work out stock gasket to be 0.18mm (2mm), 0.070" thick for a 10:1 compression ratio (86mm bore 71.5mm stroke HG bore etc). Formula states that using 1.2mm HG you get a ratio of 9:1. Using a 0.6mm gasket gives results of a 9.5:1 compression ratio. Using pistons nets you around 9.2:1 doesnt it? I cant confirm that as I can't find decent information on the dome volume of the two pistons so I can't compare them.
