Advise on Suspension Setup please
Jellybean
Just Back from Dave McCanns , Dublin Ireland
Lance Setup
http://mkiv.com/techarticles/lance_alignment/index.html
Front:
* Camber - 1.0 degrees
* Caster + 5.0 degrees
* Toe 0.00 mm
Rear:
* Camber -1.5 degrees
* Toe in (total) 1.00 mm
•3hrs on the ramp
• Wallet is 75 euro lighter
•Rear setup went all good,
•Front not so good:
1. Front Drivers Camber is still 1 Degree Out , the bolt was turning but at a certain degree it was not adjusting out any further
( we think the weight of the car was preventing the Wheel from going out)
He siad he doenst have time to work on her any more but thinks if we jack the car up and put the wheel to the max camber we can bring her in on the ramp
2. Front Passenger Camber is 10 minutes out
I was told with the centric bolts used on Toyota's and Mazda's, you cannot get it perfect plus most cars going around are out here and there. (Dont know how true this is??)
I am not too impressed by the last statement, I know Center of Gravity in the UK (http://www.centergravity.co.uk/) has done numerous UK Supra's with no issues?
He said I need to call back so he has more time to work on her; Even in the current state the car feels so much better, stable, really wants me to push her in cornors ; I would feel alot more confident in her now.
I got the last setup done by Blakes Cross @ 80 euro and 10-15 mins on the ramp; looking at the settings before Jamie touched her they where all over the place. She chewed my last set of front very badly on the inner edge.
Any advice welcome, The Supra can go to 2 degress 80 mins / 3 camber on Stock arms as far as I know , is it a good approach to take?
Jack the car up and put the wheel to the max camber we can bring her in on the ramp; (She comes in very easy on the ramp)
Or go somewhere else ?
Can you adjust the Castor on Stock arms? I have fixed rate Bilstein coilovers, not too sure if castor is adjusted on the coilover or via the suspension arms?
Castor is adjusted via the rear eccentric bolt/washer combo on the bottom arm. Camber is adjusted via the front.
The camber adjuster has limiters built into the arms so the bolt and washer will only turn so far, unlike the castor adjuster which can do complete turns unrestricted.
If the camber bolt was turning 360 degrees when Dave was trying to adjust the camber then there is a problem with that adjuster.
Thanks Damien
It was just not budging past the -1.28 + camber but if you wanted to increase the - Camber it was easy
Would the weight of the car not be an issue? Jack the car up and put Max + camber then dial it back?
A bit of toe in on the front and rear would be better as well, my car has 7 minutes on the
front and 30 minutes on the rear
Going to leave mine Front toe at 0 ; mine was eating front tyres inner edge so just want to be safe :)
