Paddle shift on auto box!
FOSTA
All 4 gears are controlled with the paddles.
Suprastick in manualised-mode has engine-braking in O.D. and 3rd, but not 2nd or 1st.
Stock ECU auto-mode has engine-braking in O.D. and 3rd but not 2nd or 1st.
Stock ECU Manu-mode has engine-braking in all gears because the 2nd and 1st gear brake-bands are controlled by the stick movement.
Sounds like my first mod when I get a TT! Does it come pre programmed or do you have to hook it up to a laptop and program it first?
Sadly, I think I am correct in saying that Suprastick will not work on a stock TT box due to the amount of solenoids it has. David will confirm this I am sure. I think you will have to do what he has done and upgrade a box from an NA by using parts from your TT box and then use that in your TT. There is another recent thread on here about just this if you have a look around. It appeals to me as well. I spoke to David last week and this also has the added advantage of control over the TC reducing the amount of slip and therefore bringing the coolant temps down.
A Suprastick ECU can control an N/A 3 solenoid valve body, but not the T.T. 4 solenoid system, which means it's plug&play for an N/A box, but not T.T.
The A343/0E Hybrid transmission I have developed uses the stronger T.T. mechanical components which are controlled with an N/A valve-body which makes it compatible with stock N/A electronics and/or Suprastick.
This transmission would work fine in a T.T. with a Suprastick standalone transmission ECU but not stock T.T. ECU.
There are other standalone transmission ECU's that claim to control the stock T.T. box, but yet to see one that has been done.
There's lots of info about the Hybrid transmission and Suprastick collated in the group link.
http://www.mkivsupra.net/vbb/group.php?groupid=57
  • 3 weeks later...
