john88 Posted June 28, 2012 Share Posted June 28, 2012 Hi everyone, I'm looking for some suggestions on my current problem with the supra. I've just returned home from holiday and took the old girl out for a quick spin since she's been parked up for over a week, I tried to open the passenger side window with the drivers switch but nothing happened. Thinking that I may have got it wet at some point (having had the same problem on a previous car) I tried the switch on the passenger door but still nothing. When I hit the switch there are no noises like the motor isn't kicking in at all, Has anyone had a similar problem? can someone suggest where to start checking things? I can't imagine that it is a fuse or relay as the driver window works fine. Thanks in advance for your replies, p.s it's an early '97 j-spec Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 28, 2012 Share Posted June 28, 2012 Fuses first, and as it doesnt work off the drivers or passengers switch it may well be a dodgy regulator Quote Link to comment Share on other sites More sharing options...
David P Posted June 28, 2012 Share Posted June 28, 2012 Maybe you've pressed the off button? Quote Link to comment Share on other sites More sharing options...
Caesard Posted June 28, 2012 Share Posted June 28, 2012 Mine stopped working all of a sudden, and after a few days, I pulled off the door card and discovered that one of the wires to the switch had pulled off. Simple fix pushing it back in. Hope that helps. Quote Link to comment Share on other sites More sharing options...
john88 Posted June 28, 2012 Author Share Posted June 28, 2012 Thanks for your replies, Guess I will be stripping the door down this weekend then Quote Link to comment Share on other sites More sharing options...
JS2004 Posted August 15, 2012 Share Posted August 15, 2012 How did it go? Ive got a similar problem currently with mine. The drivers side controls for the passenger window will make it go up, but it seems to be a bit touchy about making it go down. Sometimes it works, sometimes it wont - however it has no issue making it go down. The passenger side switch works fine though so im thinking its something to do with the driver side controls - so im interested to know how you got on with yours. Quote Link to comment Share on other sites More sharing options...
john88 Posted August 15, 2012 Author Share Posted August 15, 2012 Ah forgot about this, think it was a couple of days before a show in a mad rush to sort lol It seemed to be a bit of a dodgy connection, I pulled the wires from the switch and they looked a tad corroded so gave it a bit of a clean and all has been well Quote Link to comment Share on other sites More sharing options...
JS2004 Posted August 15, 2012 Share Posted August 15, 2012 This was the switch in the door ? the controls themselves? Quote Link to comment Share on other sites More sharing options...
john88 Posted August 16, 2012 Author Share Posted August 16, 2012 I gave both ends a go, at the switch and at the motor Quote Link to comment Share on other sites More sharing options...
