welshbuddy Posted June 28, 2012 Share Posted June 28, 2012 hey guys any had any dealings with TOMEI? came across this kit. http://www.ebay.co.uk/itm/Tomei-M8280-ARMS-Turbo-Kit-Toyota-1jz-gte-Jzx100-jzx110-jzz30-/180868686249?pt=AU_Car_Parts_Accessories&hash=item2a1c9d21a9#ht_3121wt_905 what you guys think? Link to comment Share on other sites More sharing options...
Nic Posted June 28, 2012 Share Posted June 28, 2012 They're a high quality Japanese tuning company, no experience of their turbo kits. http://www.tomei-p.co.jp/_2003web-catalogue/000_arms/product_arms_1jz-e.html Link to comment Share on other sites More sharing options...
Geo Posted June 28, 2012 Share Posted June 28, 2012 Only one way to find out im afraid, buy and test it. Then report the results. Link to comment Share on other sites More sharing options...
tkddav3 Posted June 28, 2012 Share Posted June 28, 2012 ive only ever seen skylines by them...never the supra. one way to find out Link to comment Share on other sites More sharing options...
welshbuddy Posted June 28, 2012 Author Share Posted June 28, 2012 yeh i know, but ive been reading up on them, its sais it has everything attached to bolt on, so im guessing i use the standard manifold :S? Link to comment Share on other sites More sharing options...
Kirk Posted June 28, 2012 Share Posted June 28, 2012 Tomei made a few bits for the 1JZ and the VVT-i model. The kit utilises the standard manifold. They did make a manifold for the VVT-i, not sure if it fit the standard 1JZ but there long discontinued now. Link to comment Share on other sites More sharing options...
welshbuddy Posted June 28, 2012 Author Share Posted June 28, 2012 cheers dude ill have a search Link to comment Share on other sites More sharing options...
Swampy442 Posted June 28, 2012 Share Posted June 28, 2012 If youre thinking of buying that particular one the freight, tax and duty will put the price up massively. Link to comment Share on other sites More sharing options...
Guigsy Posted June 28, 2012 Share Posted June 28, 2012 wouldnt you need 2 turbos? :S Link to comment Share on other sites More sharing options...
Swampy442 Posted June 28, 2012 Share Posted June 28, 2012 Thats a single turbo manifold... Plus later VVTI 1JZs were single turbo from the factory. Link to comment Share on other sites More sharing options...
Kirk Posted June 28, 2012 Share Posted June 28, 2012 Bollocks just had a closer look, that kit is meant for the VVt-i as a bolt on job NOT for the standard 1JZ. Swampy442 said: Thats a single turbo manifold... Plus later VVTI 1JZs were single turbo from the factory. But then again I never said that manifold was for the standard 1JZ did I Link to comment Share on other sites More sharing options...
welshbuddy Posted June 28, 2012 Author Share Posted June 28, 2012 shit i would need 2 of them? lol Link to comment Share on other sites More sharing options...
welshbuddy Posted June 30, 2012 Author Share Posted June 30, 2012 any other info? what you guys suggest? Link to comment Share on other sites More sharing options...
Swampy442 Posted June 30, 2012 Share Posted June 30, 2012 Suggest in what way mate? Link to comment Share on other sites More sharing options...
welshbuddy Posted July 1, 2012 Author Share Posted July 1, 2012 do you think i need 2 of those turbos? OR is just the one i need to buy? Bit confused it doesn't really state it . Link to comment Share on other sites More sharing options...
Nic Posted July 1, 2012 Share Posted July 1, 2012 welshbuddy said: do you think i need 2 of those turbos? OR is just the one i need to buy? Bit confused it doesn't really state it . On the link I posted earlier I believe all the cars listed as compatible are fitted with the single turbo version of the 1JZ-GTE, the Tomei turbo is meant as a direct replacement for the stock turbo using the stock manifold. If yours is a twin turbo 1JZ-GTE then you'd need a stock single turbo exhaust manifold to fit it - although I know very little about the 1JZ so don't know what would be involved in doing this. Might be worth posting on http://www.mkiiisupra.net/ for more info. Alternatively you could buy a single turbo kit that includes the exhaust manifold like this one http://www.titanmotorsports.com/1jtuki.html Link to comment Share on other sites More sharing options...
Swampy442 Posted July 1, 2012 Share Posted July 1, 2012 No that's for the single turbo VVTI as Nic said, and as Nic said you'll need a manifold as well. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2012 Share Posted July 3, 2012 A lot of my Skyline engine is Tomei. It's expensive but pretty good quality gear. Their camshafts are really nicely ground and symettrical, which is more than most are. Their orged hollow crown pistons are gorgeous, but I don't think they do them for the VVTi. As I have always said, just buy a turbo from the UK, saves a LOT of hassle when it goes wrong. Link to comment Share on other sites More sharing options...
