linconhawk Posted June 28, 2012 Share Posted June 28, 2012 Hey all, Quick question... Trying to fit these, but not having much luck... Ive tried the solder trick onto the back of the dial cluster, but no joy.... keeps breaking off.... Anyway, with the top half of the dash stripped i can see my KPH to MPH converter... On the little box it says: WHT 12V Signal (Not connected) BRN 5V Signal RED Power BLK Gnd BLU In These wires go to one of the connectors that connects to the back of the speedo cluster... So, my question is.... Can I use this to connect the Speedhut power and earth to ? Tap into the Red for the power and tap into the BLK for my earth... I hope that makes sense.... Sorry no camera to hand or multimeter to hand at the moment... Thanks Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 28, 2012 Share Posted June 28, 2012 Arn't they supposed to be only lit with the lights on Take the Gnd (white / black) & 12v (Green / other colour) feed from the ciggy lighter bulb. Lyndon. Link to comment Share on other sites More sharing options...
linconhawk Posted June 28, 2012 Author Share Posted June 28, 2012 Yeah, I want them only to come on when the lights are on... Connecting to the wires you have said (ciggy plug) will they only come on when lights are on then ? Yeah, thinking about what I said, they would be on the whole time !!! OOOoooppppsssss :o) Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 28, 2012 Share Posted June 28, 2012 Yeah, I want them only to come on when the lights are on... Connecting to the wires you have said (ciggy plug) will they only come on when lights are on then ? Yeah, thinking about what I said, they would be on the whole time !!! OOOoooppppsssss :o) Remember you want to connect to the Ciggy lighter Bulb (Small grey plug), not the actual ciggy lighter power feed (big white plug). Lyndon. Link to comment Share on other sites More sharing options...
linconhawk Posted June 28, 2012 Author Share Posted June 28, 2012 ah yes... right, all connected, ive just reffited speedo cluster only and they dont work !!! ??? 2 things... Do all the connectors to the dash need to be connected. ? and does the bulb need to be working in the cig lighter ? im not sure if this worked before hand... ? Thanks Link to comment Share on other sites More sharing options...
supra steveo Posted June 28, 2012 Share Posted June 28, 2012 sounds like you need some better solder ? I am sure i did a how to fit dials thread Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 28, 2012 Share Posted June 28, 2012 If you don't have the Dimmer Rheostat connected you won't get any dash lights. Lyndon. Link to comment Share on other sites More sharing options...
supra steveo Posted June 28, 2012 Share Posted June 28, 2012 http://www.mkivsupra.net/vbb/showthread.php?145162-Fitting-EL-Glo-Dials here u go .................. by the way where did mr pot go to ???? i miss his drunken antics lol Link to comment Share on other sites More sharing options...
linconhawk Posted June 28, 2012 Author Share Posted June 28, 2012 Hey Guys, All working now.... It turned out you need most of the dash connections connected back up again.... Lyndon - Thanks for your advise. Thanks Link to comment Share on other sites More sharing options...
sideexitsupra Posted June 28, 2012 Share Posted June 28, 2012 Ha ha, I recently fitted some similar dials and it was driving me mad that they didn't work. Then I realised the right hand dash panel was off and the dimmer disconnected. Dufus! Link to comment Share on other sites More sharing options...
DodgyRog Posted June 28, 2012 Share Posted June 28, 2012 Ha ha, I recently fitted some similar dials and it was driving me mad that they didn't work. Then I realised the right hand dash panel was off and the dimmer disconnected. Dufus! I did the same:innocent: Link to comment Share on other sites More sharing options...
