viper Posted June 26, 2012 Share Posted June 26, 2012 Iv got a manual boost controller, while i save up for the electric one i want. I thought id check to see how people recomend fitting them with the TT setup. Any help much appreciated. Link to comment Share on other sites More sharing options...
spikedjack Posted June 26, 2012 Share Posted June 26, 2012 i'd probably fit it the exact same way as an EBC but back it off to around 1.1 bar to allow for temperature spikes Link to comment Share on other sites More sharing options...
Shane Posted June 26, 2012 Share Posted June 26, 2012 In your signature you say you have a BPU, in that case you must already have a boost controller be it mannual or electric I would think. Link to comment Share on other sites More sharing options...
dcarrter21 Posted June 26, 2012 Share Posted June 26, 2012 I used a manual boost controller, it was bad news. Caused really bad boost spike so i removed it and just waited to buy an electronic one. Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 26, 2012 Share Posted June 26, 2012 i'd probably fit it the exact same way as an EBC Actually, that's not the recommended way. I'll pm you a link with a guide shortly matey. Link to comment Share on other sites More sharing options...
viper Posted June 27, 2012 Author Share Posted June 27, 2012 iv fit one of these before on a turbo mx5 but obviously only having a sungle turbo set up it just went between the actuator and turbo. having a TT setup is there a spacific line for the MBC to tap into? Link to comment Share on other sites More sharing options...
ashbuster Posted June 27, 2012 Share Posted June 27, 2012 (edited) is this the type you have? http://www.mkiv.com/techarticles/bleedert/bleedert.htm Edited June 27, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
viper Posted June 27, 2012 Author Share Posted June 27, 2012 ah i think i just over looked one of the hose pictures, as it shows which pipe to put the MBC in. mines not ones of these £10 ebay ones its a little beefier. I think ill be ok now. Link to comment Share on other sites More sharing options...
ashbuster Posted June 27, 2012 Share Posted June 27, 2012 yeah instead of putting the t-piece in to run the bleeder you just fit the manual boost controller there dont you mate? Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 27, 2012 Share Posted June 27, 2012 yes Link to comment Share on other sites More sharing options...
ashbuster Posted June 27, 2012 Share Posted June 27, 2012 thought so Link to comment Share on other sites More sharing options...
