Jellybean Posted June 25, 2012 Share Posted June 25, 2012 Hey I have the Sard Mig Arouse Exhaust , I want to keep my twin silence box setup but is it possible to bolt up a different back box? Something simliar to a hks/ blitz/boostlogic style http://www.enigma-penguin.net/thumb-images/IMG_6330.JPG Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2012 Share Posted June 25, 2012 They wouldn't just bolt up to you're mid pipe they'd need some cutting and welding to make them fit. May be easier to get a new back box fabricated to fit. Link to comment Share on other sites More sharing options...
Jellybean Posted June 25, 2012 Author Share Posted June 25, 2012 They wouldn't just bolt up to you're mid pipe they'd need some cutting and welding to make them fit. May be easier to get a new back box fabricated to fit. thanks Nic , do you reckon it will sound louder ; would the Sard back box also implement some form or noise reduction too? What Back box manufacturer would you recommend for the style I am after? Not too sure if you can just buy them seperate, cant find any Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2012 Share Posted June 25, 2012 The back box does reduce the sound, by how much depends on the size, design and sound deadening material used inside. There are UK companies that sell off the shelf back boxes, Whifbitz also get their exhausts manufactured locally, may be worth contacting Paul to see if he can supply you what you need. You could then get the pipe from the SARD back box cut off and welded onto the new back box so it would fit the mid pipe. http://www.vortex-performance-exhausts.co.uk/products http://www.powerflowexhausts.co.uk/products/ http://www.jetex.co.uk/ Link to comment Share on other sites More sharing options...
