v6shep Posted June 25, 2012 Share Posted June 25, 2012 ello peoples, just been looking around, cant seem to find the help im needing, my drivers seat reclines as should, but is not shifting back or forth and is at the mo set as far back as it can go, the motor is making the noises it should, but not moving, is there a way i can manually do this until i find a new seat?? cheers in advance, shaun Quote Link to comment Share on other sites More sharing options...
Josh42 Posted June 25, 2012 Share Posted June 25, 2012 Yes pal, there's a guide on here somewhere, Basically remove the 2 screws retaining the plastic cover on the front of the seat. You'll see a 10mm nut on the right and a 12mm nut on the left, wind those equally out and your seat will move forward/back depending on the direction which you turn the nuts. Quote Link to comment Share on other sites More sharing options...
v6shep Posted June 25, 2012 Author Share Posted June 25, 2012 thanks buddy, ill look into that Quote Link to comment Share on other sites More sharing options...
