linconhawk Posted June 24, 2012 Share Posted June 24, 2012 Hey all, Couple of silly questions.... Im sure they are all correct, but just wanted to make sure..... Pic of my stereo.... does it look fitted correctly ? its just there is a gap around the stereo, showing the metal bracket things behind..... or should it have a plastic surround cliped to it ??? My driver and passenger door window switch panels.... Drivers one is plastic, passenger's has a leather finish... Im sure this is correct, but just wanted to make sure.... Also, im going to be getting my dash panels sprayed soon by my local body shop.... Do, I also get the drivers door switch panel sprayed to match and leave the passenger one leather... ? will that look odd... ? Cheers... Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 24, 2012 Share Posted June 24, 2012 Head unit should have a plastic trim around it however they don't always fit so people remove them like yours, switches look fine, if your painting dash panels you need to remove the rubber coating before you prep and spray which is a total nightmare.... I used IPA which I got off eBay, also if your spraying them black I found I got glare off them reflecting the sun. Quote Link to comment Share on other sites More sharing options...
shaky Posted June 24, 2012 Share Posted June 24, 2012 The trim is missing.......http://www.amazon.co.uk/Panasonic-CQ-RDP-152N-Car-Stereo/dp/B00008VIIL Quote Link to comment Share on other sites More sharing options...
linconhawk Posted June 24, 2012 Author Share Posted June 24, 2012 Head unit should have a plastic trim around it however they don't always fit so people remove them like yours, switches look fine, if your painting dash panels you need to remove the rubber coating before you prep and spray which is a total nightmare.... I used IPA which I got off eBay, also if your spraying them black I found I got glare off them reflecting the sun. What do you mean by they dont always fit.... ? Yeah I know about the rubber coating stuff..... My body shop will deal with that problem... he he... Was going to go with a dark grey colour.... Quote Link to comment Share on other sites More sharing options...
linconhawk Posted June 24, 2012 Author Share Posted June 24, 2012 The trim is missing.......http://www.amazon.co.uk/Panasonic-CQ-RDP-152N-Car-Stereo/dp/B00008VIIL I know there should be a plastic trim, but will it fit on... ? Ive seen other supras the same as mine, with no surround trim.... ??? Thanks Quote Link to comment Share on other sites More sharing options...
shaky Posted June 24, 2012 Share Posted June 24, 2012 If you take the dash panel off you can space the unit out a bit then the trim will clip on. Quote Link to comment Share on other sites More sharing options...
linconhawk Posted June 24, 2012 Author Share Posted June 24, 2012 Ok, cool, thanks Quote Link to comment Share on other sites More sharing options...
Supranature Posted June 24, 2012 Share Posted June 24, 2012 Head unit should have a plastic trim around it however they don't always fit so people remove them like yours, switches look fine, if your painting dash panels you need to remove the rubber coating before you prep and spray which is a total nightmare.... I used IPA which I got off eBay, also if your spraying them black I found I got glare off them reflecting the sun. What do you mean by they dont always fit.... ? Yeah I know about the rubber coating stuff..... My body shop will deal with that problem... he he... Was going to go with a dark grey colour.... I think he means get it done in a satin or matt finish Quote Link to comment Share on other sites More sharing options...
