The Raven Posted June 23, 2012 Share Posted June 23, 2012 Well today i should have been more or less done with the car. Having started it up all seemed fine for the little time it was run, (i had no exhaust on it) so today me and col fitted the exhaust, induction kit and pushed it out side. It fired first time and chucked out all the crap that would would expect to see from an engine that been sitting for a while. Then it started to idle high, then reving higher still then jumping up and down, touch the throttle a little and it sounds like its open right up? I Should add its running a normal stock ecu, no other mods. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 23, 2012 Share Posted June 23, 2012 Just a guess but is the TT throttle cable fitted correctly? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted June 23, 2012 Share Posted June 23, 2012 Icv might be worth checking its probobly full of cack try cleaning it out Quote Link to comment Share on other sites More sharing options...
RobD Posted June 23, 2012 Share Posted June 23, 2012 As said throttle cable or icv! Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 23, 2012 Author Share Posted June 23, 2012 I took the cable off to see what would happen, Alas it still did it. ICV check then. Thanks loads. Quote Link to comment Share on other sites More sharing options...
Geo Posted June 23, 2012 Share Posted June 23, 2012 sounds like there is air getting in the throttle body somewhere. last year at pod after i did a run up the strip, a hose had popped of the plenum and my revs went through the roof, it drove like it wanted to go faster, but soon as i popped it into neutral the revs went through the roof. check all hoses, on the plenum side. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted June 23, 2012 Share Posted June 23, 2012 Yeah that ^ same happend to me, it was a split hose on the plenum Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 24, 2012 Author Share Posted June 24, 2012 Good newz col gave me a ring after cleaning out the icv and all seems fine now. I will still check for air leaks. Thanks guys Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 24, 2012 Share Posted June 24, 2012 Make sure as well, all the bolts holding the plenum to the runners and the head are tight. Quote Link to comment Share on other sites More sharing options...
