Manual electric aerial?
Josh42
Looking to try and fit a switch so I can manually control the electric aerial on the car.
Does anybody have any advice?
Does the aerial wire run down the centre of the car or down the drivers side?
Cheers
Josh
The easiest place to do this is at the signal wire at the radio connectors. There is a wire (seem to remember it being blue with a white stripe) running from the radio to the antenna. Simply insert a on/off switch there. Its working perfectly for me. It have it off 99,99% of the time and the antenna is down. Should I need better radio reception I just switch it to on and the antenna goes up. You don't have to mess with the 12V signal at all.
