Guest jamesgui Posted June 21, 2012 Share Posted June 21, 2012 Vibration on idle, car runs perfect at 1000 rpm. I have checked engine mountains- look OK but still have my suspicions? Vibration slightly worse under load when drive selected. No single isolated vibration, whole car vibrates. Slightly less when neutral selected due to increase in idle speed,but SAME vibration still physical and audible Any ideas would be appreciated as engine mountains are over £200 and Dealer part only JIM Quote Link to comment Share on other sites More sharing options...
firin Supra Posted June 21, 2012 Share Posted June 21, 2012 I had this problem a while back when i had the jdm tt supra i had everything checked out but no one could help it was annoying and on it in drive i remember the steering use to vibrate alot i hope you can get to the bottom of it Quote Link to comment Share on other sites More sharing options...
dan294 Posted June 21, 2012 Share Posted June 21, 2012 I'd guess at engine mounts: http://www.mkivsupra.net/vbb/showthread.php?267415-New-engine-mounts-fitted-100-recommend-this!!&highlight=engine+mounts+jurgen Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted June 21, 2012 Share Posted June 21, 2012 Are you sure it's not a misfire? I thought my old aerotop had a vibration, but it was the old plugs causing a miss on idle. Worth a quick check before spending out on mounts Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 21, 2012 Share Posted June 21, 2012 I had a video uploaded to utub a few weeks back, comment where running "mint", the engine is like mouse chewing the a page out of playboy. The vibration is not visible anywhere under the bonnet,its only when you sit in the car,its so subtle in neutral,but annoying when drive is selected. I think the mounts are just past the sell by date,but VERY expensive to buy and get it wrong. But at present I think a cogent case for engine mountains. Just exploring the huge knowledge and experience of the members Thanks in advance for all help Jim Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 21, 2012 Share Posted June 21, 2012 Anybody know of a good source for Engine Mounts? Quote Link to comment Share on other sites More sharing options...
Havard Posted June 21, 2012 Share Posted June 21, 2012 (edited) This is defo engine mounts with the symptoms you describe. Edited June 21, 2012 by Havard (see edit history) Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 21, 2012 Share Posted June 21, 2012 My car, same symptoms. 'P' ok. 'N' ok. 'D, 2, L', with brake, bad vibration. Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 21, 2012 Share Posted June 21, 2012 I am going for engine mounts-will update next week.\ Thanks jim Quote Link to comment Share on other sites More sharing options...
