Where is best to go for a stock 6sp TT clutch?
rider
My 1996 TT 6 speed has done 103k on the original clutch which I reckon is good going but it has the occassional slip. To be honest it first had a slip 5 years ago but I only do a few thousand miles in it each year. The slippage is still very occassional and generally from a low down boot rather than a high rev thrash. I want to line up a replacement for the next service/MOT visit to the garage. You see the occassional one come up on e-Bay but I was wondering if anyone can share a good company or site to go sort out a replacement.
The car was dyno tested in the not too distant past and recorded 330bhp at the drive wheels so it has had a BPU in its early life. nothing serious though so a stock clutch will do fine.
How about Chris Wilsons clutch? Its a stock clutch with a mildly upgraded spring that fits your powerlever perfectly. I didn't notice any change in pedal pressure even though Chris told me there should be a slight difference. I don't rember the price but it was very reasonable
Ditto - he's in your neck of the woods too :)
My uprated stock clutch should be ideal, can supply only, or supply and fit, please see below. i also do them for the N/A 5 speed boxes.
I use the stock, brand new driven plate, as it is correctly
balanced, doesn't judder and will hold all but mega torque
highly modded engines or cars used for drag racing.
I modify a stock brand new cover to give more clamping force.
The reason I tooled up to do these is some of the aftermarket
US clutches I have fitted SEEM to be built from used cover
assemblies with reground friction surfaces, and a stronger
spring. I have had hellish trouble getting these to fully
release, because due to this seemingly thinner cast iron
friction face, the geometry of the clutch goes to pot, and
being a pull type clutch (the hydraulics pull the bearing
away from the engine, rather than the more normal push type)
it is a lot harder to effect a cure.
For 455 pounds plus VAT , you get a brand new driven
plate, a brand new modded cover, and a brand new release
bearing. I would rather fit myself so any complaints are down
to me, I see a lot of clutches damaged by people without the right gear
(a ramp and transmission jack, plus correct circlip tools and fitment)
or clutches fitted to patently *uggered flywheels. I will do a supply
only if you feel competent to tackle the job or are using a bona fide garage to
fit the clutch
Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and
outer assembly, damped in the middle) which is now showing signs
of wear causing a lot of rattle when idling or on very light
throttle openings. For God knows what reason they are charging
about £400 + VAT for a new one, they look more like they should be
over 500 to me, but don't say anything :-) The very similar LUK dual
mass flywheel on Maseratis is nearly £1000 + VAT.... So if the flywheels
old enough or abused enough to be scored it should be replaced.
Fitting by myself will cost £175 + VAT.
Reply privately if interested please. [email protected]
