iainc Posted August 8, 2005 Share Posted August 8, 2005 please help. Whilst driving at about 65-70 i get my engine managment light and warning triangle coming on and staying on also the o/d light starts flashing the lights stay on till i turn engine off. As soon as i start driving again and get 2 those speeds again they come back on and stay on. PLEASE SOMEONE HELP. Link to comment Share on other sites More sharing options...
Ian C Posted August 8, 2005 Share Posted August 8, 2005 Step 1 - Check your stored error codes and let us know what they are -Ian Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 8, 2005 Share Posted August 8, 2005 Step 1 - Check your stored error codes and let us know what they are -Ian my vote for ian c as the technical guru Link to comment Share on other sites More sharing options...
Jezz Posted August 8, 2005 Share Posted August 8, 2005 I have the same problem with my o/d light flashing. Just done a fault reading as described, but the Mil exclamation mark doesn't flash! The 'ecu' warning light however does flash constantly. A little help please!! Link to comment Share on other sites More sharing options...
iainc Posted August 8, 2005 Author Share Posted August 8, 2005 just read the codes and only 1 is coming up CODE 42 Link to comment Share on other sites More sharing options...
Ian C Posted August 8, 2005 Share Posted August 8, 2005 Speed sensor, dodgy speed convertor/top speed delimiter wiring, light lights up the first time you give it some beans, yes? Don't even have to look that one up any more -Ian Link to comment Share on other sites More sharing options...
Ian C Posted August 8, 2005 Share Posted August 8, 2005 I have the same problem with my o/d light flashing. Just done a fault reading as described, but the Mil exclamation mark doesn't flash! The 'ecu' warning light however does flash constantly. A little help please!! Yeah, it's the engine warning light that flashes, the FAQ may be a bit ambiguous but you figured it out That means no stored codes. I have no experience with the autobox -Ian Link to comment Share on other sites More sharing options...
Jezz Posted August 8, 2005 Share Posted August 8, 2005 Cheers ian . After carefull consideration i'm going to take the technical route to problem solving..................take all the bulbs out!! LOL Link to comment Share on other sites More sharing options...
Ian C Posted August 8, 2005 Share Posted August 8, 2005 Do you ever get into 4th gear? Can someone with an autobox chip in please? -Ian Link to comment Share on other sites More sharing options...
Jezz Posted August 8, 2005 Share Posted August 8, 2005 Yeah the actual o/d works fine. Clearly changes up and down as you switch the button. Changes up to forth fine, Light stays on as it should when o/d is off, but when its on the light flashes like a pervert in a rain coat! Drivin me nuts!! Link to comment Share on other sites More sharing options...
imi Posted August 8, 2005 Share Posted August 8, 2005 Speed sensor, dodgy speed convertor/top speed delimiter wiring, light lights up the first time you give it some beans, yes? Don't even have to look that one up any more -Ian Ian. I got a new THOR converter fitted and am getting the same problem. Only issue is that it is intermittent, so there is no way for me to pin point exactly whether it is going to happen the next time I go over 60-65mph for example, the last time the triangle and engine light lit up was a week ago. Whats the best way to troubleshoot these types of issues. Regards Link to comment Share on other sites More sharing options...
iainc Posted August 8, 2005 Author Share Posted August 8, 2005 changes through the gears ok, got new sensor fitted 2day but its still happening car hasn't been played with as yet (converter or delimiter) Link to comment Share on other sites More sharing options...
Jspec Germany Posted August 9, 2005 Share Posted August 9, 2005 I'll jump in at this point. I've been working this problem for some time. By working, I mean gathering information. The wrenching will start this week with a THOR SLD, I hope! First off, is the car an auto? As Ian mentioned, if you have a code 42, several things can be the fault. Here is the list I have compiled so far: dodgy wiring at ECU caused by Speed Delimiter or Speedo conversion installation, faulty/old solder points on back of odometer. I've also heard that the wiring at the back of the speedo could be the fault. I'm thinking that a turbo timer which sh*t the bed may be my cause. I've yet to hear however that the speed sensor itself was to fault. Do you have always-light-steering or have you had any issues with cruise control or the active front spoiler? These are all speed-sensitive devices and subject to problems due to this code. Ian C, if you tell me how to post links to other threads, I can pass on those links that I've compiled regarding this fault. Hope this helps fellas. Feel free to ask questions and share with us your resulting fix actions as you troubleshoot. Link to comment Share on other sites More sharing options...
iainc Posted August 9, 2005 Author Share Posted August 9, 2005 my car is a n/a auto with no traction control no active spoiler no cruise control and no Speed Delimiter. Link to comment Share on other sites More sharing options...
Jspec Germany Posted August 9, 2005 Share Posted August 9, 2005 What year and is it u.k. or jspec? I'll link the other threads to you. Link to comment Share on other sites More sharing options...
Jspec Germany Posted August 9, 2005 Share Posted August 9, 2005 Read this thread: http://www.mkivsupra.net/vbb/showthread.php?t=38463 Link to comment Share on other sites More sharing options...
JustGav Posted August 9, 2005 Share Posted August 9, 2005 I know stevie_b had the same issue on his manual NA, and I gave him a spare odo which seemed to solve the problem... Apart from that he didn't have any other issues other than the code 42... Gav Link to comment Share on other sites More sharing options...
Ian C Posted August 9, 2005 Share Posted August 9, 2005 Read this thread: http://www.mkivsupra.net/vbb/showthread.php?t=38463 That's how you post a link btw -Ian Link to comment Share on other sites More sharing options...
secondjump Posted August 9, 2005 Share Posted August 9, 2005 I had a problem concerning "code 42" which had me pulling my hair out for ages. Initial symptoms were: a) Active spoiler light flashing and spoiler not dropping when it should. b) Engine management light coming on after hitting 60mph. Which progressed to: c) O/D light flashing intermittently. d) Gearbox intermittently giving up the ghost until speeds of less than 10mph were reached then limp home mode - couple of occasions via low loader. Final solution for me was: Contacted Emin, who came over and like me could not find the converter but as a guess tried the 'bypass a bit of circuitry in the odo' job and all the listed problems have since vanished. ....auto btw Link to comment Share on other sites More sharing options...
iainc Posted August 9, 2005 Author Share Posted August 9, 2005 mine is an auto j-spec. Link to comment Share on other sites More sharing options...
secondjump Posted August 9, 2005 Share Posted August 9, 2005 mine is an auto j-spec. I would get the odo looked at, i'd say that's your culprit Link to comment Share on other sites More sharing options...
iainc Posted August 9, 2005 Author Share Posted August 9, 2005 ok will have 2 borrow 1 from someone 2 try on car. car has already had a new sensor (speed i think) and have checked the pink wire which is in 1 piece. Link to comment Share on other sites More sharing options...
Ian R Posted August 9, 2005 Share Posted August 9, 2005 Yeah the actual o/d works fine. Clearly changes up and down as you switch the button. Changes up to forth fine, Light stays on as it should when o/d is off, but when its on the light flashes like a pervert in a rain coat! Drivin me nuts!! I'm no expert but is the Traction Control light flashing aswell. There is a connection on the throttle body (black) that controls TC and can sometimes work itself lose. Try unscrewing it and put it back in place reset the ECU and see if that makes a difference Link to comment Share on other sites More sharing options...
imi Posted August 10, 2005 Share Posted August 10, 2005 Contacted Emin, who came over and like me could not find the converter but as a guess tried the 'bypass a bit of circuitry in the odo' job and all the listed problems have since vanished. ....auto btw Bypasses a bit of circuitry?? does your ODO still read in miles??? Link to comment Share on other sites More sharing options...
iainc Posted August 10, 2005 Author Share Posted August 10, 2005 odo reads in k still. want 2 convert it to read miles but want it reprogramd so it reads a true milage. Link to comment Share on other sites More sharing options...
