Grinding noise.
Rajinder
After my track day on Friday I have started getting grinding noise from the front and the viberation is also felt on the brake pedal. The noise is coming only when the car is moving, so that rules out any engine problems. Checked all the springs on the struts and they are all seated perfectly and the noise do not come when you turn the steering when the car is stationary. Jacked all four tyres for bearing failure but they again are perfect no play. Checked the brake pads and are fine and seated.
Any help will be much appreciated.
  • 2 weeks later...
