ray007 Posted June 17, 2012 Share Posted June 17, 2012 Hi all Need some help with my project which is being built from a shell. Could anyone advise on the correct SIZE (diameter and length) of the fuel INTAKE & RETURN hoses? Many thanks in advance Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 21, 2012 Author Share Posted June 21, 2012 any one pleeeeasse? Quote Link to comment Share on other sites More sharing options...
Hoppy Posted June 22, 2012 Share Posted June 22, 2012 What sort of power do you plan to run?? Quote Link to comment Share on other sites More sharing options...
johnny g Posted June 22, 2012 Share Posted June 22, 2012 Check the "built" fuel kits from Titan/PHR/MVP etc and see what they use. Stock rail accepts -6 with a small adapter. That'll support 500whp. Aftermarket fuel rails take -8 (Like Whifbitz). They'll take 800whp, etc. A bit more information would be good. Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 22, 2012 Author Share Posted June 22, 2012 Thanks buddy It will be actually running just bpu power with Walbro fuel pump,fmic,fcd double decat/aftermarket exhaust and w58 box. So for stock I should use a -6 hose? Check the "built" fuel kits from Titan/PHR/MVP etc and see what they use. Stock rail accepts -6 with a small adapter. That'll support 500whp. Aftermarket fuel rails take -8 (Like Whifbitz). They'll take 800whp, etc. A bit more information would be good. Quote Link to comment Share on other sites More sharing options...
johnny g Posted June 22, 2012 Share Posted June 22, 2012 You've no need to use anything other than stock lines for that Quote Link to comment Share on other sites More sharing options...
Hoppy Posted June 22, 2012 Share Posted June 22, 2012 Agreed Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 22, 2012 Author Share Posted June 22, 2012 You've no need to use anything other than stock lines for that Agreed Thanks for your input guys But I shoul have explained the reason I'm asking as I'm building a supra from a rolling shell. So it didn't come with the fuel tanks and lines, I've managed to get a tank but no fuel lines so thought il try get some made. Any pics or diagrams will be helpful Many thanks for your time guys Quote Link to comment Share on other sites More sharing options...
Hoppy Posted June 22, 2012 Share Posted June 22, 2012 In that case, a single AN6 line should be sufficient. I would imagine 5-6 metres would be more than enough mate, and a AN6 fuel filter to suite. Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 22, 2012 Author Share Posted June 22, 2012 In that case, a single AN6 line should be sufficient. I would imagine 5-6 metres would be more than enough mate, and a AN6 fuel filter to suite. ah thank you sooo much, i knew i could rely on a member of this forum :-) Quote Link to comment Share on other sites More sharing options...
