TubbyTwo Posted June 17, 2012 Share Posted June 17, 2012 Hi all, Firstly the car is an NA-TT auto with a Toad Ai606 fitted. I need some help with the car, what started off as just a simple job of removing a gauge pod and 2 gauges (boost and oil temp) and a turbo timer has turned into a mini nightmare. I have removed all dash panels as they need repainting and I intend to move the oil temp gauge to where the clock currently lives in the dash. I have removed the turbo timer and its connector that was spliced into the ignition loom under the steering wheel, this was fitted by just stipping back wires on both parts and splicing together. I have removed these from the loom and taped up any exposed wire. So logically this has just been put back to stock, now, spliced into the turbo timer "loom" was power to the HKS EVC and the 2 gauges. As all of this is being removed and was now no longer needed, the whole lot was clipped and removed. I have put all the earths back how they were minus the ones removed, the car is in park and everything works EXCEPT it wont actually start. The car turns over but wont fire. I have checked and double checked everything I have done and I cant see anything cut or disconnected that wasnt before and I havent touched anything belived to be alarm related. Same as before if the car is left without the key in for a min or so it wont even turn over (until the car is locked then unlocked with the alarm fob) which i assume is the immobiliser working, this happened before I took everything out. any help would be great /vbb/images/smilies/bbcode_sad.gif /vbb/images/smilies/bbcode_sad.gif Thanks all Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 17, 2012 Author Share Posted June 17, 2012 wondering if i have possibly disturbed some wiring. any fuses that could stop the car from starting?? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 17, 2012 Share Posted June 17, 2012 have you checked all your fuses mate? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 17, 2012 Author Share Posted June 17, 2012 that's the next stage. its not putting any fuel in so wonder if the efi fuse has popped. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 17, 2012 Share Posted June 17, 2012 check them all mate , i know its a pain in the arse but if they are all fine atleast you can rule fuses out Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 17, 2012 Author Share Posted June 17, 2012 yeah will check the lot. will also try putting all the dash panels on. have the speedo cluster in and connected but nothing else. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 17, 2012 Share Posted June 17, 2012 should be fine without the rest of the dash in bud mine works fine anyway, you just have no indicators when the hazards switch is unplugged lol and no dash lights with the dimmer unplugged Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 17, 2012 Author Share Posted June 17, 2012 cheers mate Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 20, 2012 Share Posted June 20, 2012 did you have any luck with this mate? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 20, 2012 Author Share Posted June 20, 2012 tbh not looked yet although hoping its just a fuse somewhere Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 20, 2012 Share Posted June 20, 2012 yeah i would imagine Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 20, 2012 Author Share Posted June 20, 2012 I have removed so much dead wiring its untrue, so I might actually be able to get near the fuse box now. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 22, 2012 Author Share Posted June 22, 2012 Sorted, was one of the EFI fuses in the engine bay. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 22, 2012 Share Posted June 22, 2012 good news nice to hear it was easily sorted Quote Link to comment Share on other sites More sharing options...
