dacky20 Posted June 17, 2012 Share Posted June 17, 2012 (edited) i have a 1999 3.0 n/s soarer with auto box i have owned the car a short while and its has recently developed an issue with the box when i put it in drive it only uses 3rd and 4th there is no 1st 2nd but if i use overdrive i can select 1st 3rd and 4th i have the o/d off light flashing on the dash every 3seconds also???? i have tried diagnostics using the port and i dont get any faults just a constant flash check oil when warm and running and its slightly low but nothing major any thought theorys would be great as im stuck skipping gears which carnt be good for my car ! cheers boys Edited June 17, 2012 by dacky20 (see edit history) Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 ??? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 Sounds like a speed sensor issue, try getting the codes again. Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 Sounds like a speed sensor issue, try getting the codes again. tried getting the codes and nothing just a constant flash from the engine management light tried 3 separate times where is the speed sensor located inside or outside the gearbox ? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 They're both outside the box. Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 is there any way of telling if they are no good mate ? Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 They're both outside the box. also what color should the box oil be mine looks very light like engine oil ? Quote Link to comment Share on other sites More sharing options...
Shane Posted June 17, 2012 Share Posted June 17, 2012 (edited) Before you get too deep into fault finding on this one do this: http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix&highlight=pink+wire+mod It only takes a few minutes and can save you a lot of hassle. Also, your fluid should be a translucent cherry red colour without any floaters in it. But if its been cooked at some point can take on a brownish hue. Have a search as there are quite a few threads on here about changing transmission fluid. Normally if you dont think you need to do the whole thing which isnt that difficult just requires a couple of clean buckets and some hose, then most just change whats in the sump. Edited June 17, 2012 by Shane Added a bit (see edit history) Quote Link to comment Share on other sites More sharing options...
neil tt Posted June 17, 2012 Share Posted June 17, 2012 And it stinks Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 If the fluid is anything other than cherry red it needs changing. That won't help your problems. I'd certainly drain the fluid, flush the torqu converter, drop the gearbox sump and check the filter as well. *edit, also you do know how to correctly check the fluid level as well don't you? Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 Before you get too deep into fault finding on this one do this: http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix&highlight=pink+wire+mod It only takes a few minutes and can save you a lot of hassle. Also, your fluid should be a translucent cherry red colour without any floaters in it. But if its been cooked at some point can take on a brownish hue. Have a search as there are quite a few threads on here about changing transmission fluid. Normally if you dont think you need to do the whole thing which isnt that difficult just requires a couple of clean buckets and some hose, then most just change whats in the sump. you say this but will it give me my 2nd gear back or just get rid of the light ? when i put it in drive /auto it try to set of in 3rd and then goes into 4th fine when needed ???? i have no 1st 2nd in auto but i can manualy select 1st but not 2nd ! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 Is this a soarer or a supra? On Driftworks you say it's a soarer? Quote Link to comment Share on other sites More sharing options...
dacky20 Posted June 17, 2012 Author Share Posted June 17, 2012 yeh soarer sorry same i think tho you guys are more helpful too Quote Link to comment Share on other sites More sharing options...
Shane Posted June 18, 2012 Share Posted June 18, 2012 you say this but will it give me my 2nd gear back or just get rid of the light ? when i put it in drive /auto it try to set of in 3rd and then goes into 4th fine when needed ???? i have no 1st 2nd in auto but i can manualy select 1st but not 2nd ! TBH when I read your symptoms again I doubt wether it will be your problem, but I know from experience that the buffer circuitry in the odo that this mod bypasses gives some really weird problems in terms of random gear changes, not changing at all and shift points changing. It only takes a few minutes to do and I would eliminate it first. Thats assuming the odometer is the same on a soarer. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 18, 2012 Share Posted June 18, 2012 Have you got a speed convertor fitted? Quote Link to comment Share on other sites More sharing options...
