fordy_alexsupra Posted June 16, 2012 Share Posted June 16, 2012 Doing a light fluid change (2 litre). I have no idea what fluid is currently in the box atm but anyway which is the recommended Fluid Type from toyota? ATF TYPE T–II (from workshop manual) or ATF TYPE IV Also is Redline Fluid recommended or stick with Toyota? Cheers, any help would be great. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 16, 2012 Share Posted June 16, 2012 I've always used Dextron III on all my Toyota boxes, recognised replacement for the type II fluid. If you want to go hardcore on the box service get a gearbox filter from Toyota as well. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 16, 2012 Share Posted June 16, 2012 ive always used ATF type IV, Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 17, 2012 Author Share Posted June 17, 2012 Filter , I never! From toyota, do the gearbox filters come as OEM for the Tripronic Boxes? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 All auto boxes have filters, its internal so you have to drop the sump to change it. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 17, 2012 Author Share Posted June 17, 2012 All auto boxes have filters, its internal so you have to drop the sump to change it. Ahh thanks, and re-seal the sump with toyota sealant (black)? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 Yep Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 17, 2012 Author Share Posted June 17, 2012 Cool, so where do you buy your dextron III? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2012 Share Posted June 17, 2012 I just get it from halfords mate. Quote Link to comment Share on other sites More sharing options...
Iky Posted June 20, 2012 Share Posted June 20, 2012 Halfords sell a 5L can of I think Comma Dexron iii. Cost me £12.50 with a trade card. i think normal price is about £15. Works out a lot cheaper than the little 1L bottles but then you need a decent funnel as the 5L doesn't come with a spout. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Halfords sell a 5L can of I think Comma Dexron iii. Cost me £12.50 with a trade card. i think normal price is about £15. Works out a lot cheaper than the little 1L bottles but then you need a decent funnel as the 5L doesn't come with a spout. Good to know, I was just going to check ebay prices for a 5l as well and I have 0.5l poring cans at work . How would I go about doing a full gearbox oil flush and refill?? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 20, 2012 Share Posted June 20, 2012 I will be doing this shortly as well Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted June 20, 2012 Share Posted June 20, 2012 Christ Wilson did a full atf flush and filter change on my autobox and it has been so much smoother since, money well spent Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Christ Wilson did a full atf flush and filter change on my autobox and it has been so much smoother since, money well spent Ahh maybe I will pm him, I know the filter is in the sump as someone said above should be easy enough. Just the next part, the full flush and refill? I'm thinking disconnect the igniter, turn the car over in 'P' or 'N' with the oil out let line disconnected? Could be bad though turning the gears dry. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Or, Dissconect the oil outlet line into a bucket. Turn engine on. Quickly fill with oil, through the filler plug or dipstick(?) as it pumps out in to bucket. Stop when it is clear of old fluid. Can it be done safely? Quote Link to comment Share on other sites More sharing options...
Robzki Posted June 20, 2012 Share Posted June 20, 2012 A full flush isn't a good idea on an autobox. iirc better to do regular 2 ltr drain and refills Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 20, 2012 Share Posted June 20, 2012 Is there any easy way to fill the box if the level is low? or is it a case of pouring it down the dipstick hole? Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Dipstick hole will be fine as from manual. In the manual it has nothing on a full flush so 2 ltr drain and refills is the way to go for me, new Toyota T-IV ATF has sufficient additives to maintain this coating and also enough co-polymers to rekindle the older ATF. The older ATF is still red anyway, only just gone bpu so needes a maintain! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 20, 2012 Share Posted June 20, 2012 Dont start the engine! Just turn it over with the ignition disabled. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 (edited) Thought that was the safer and more controlled way yes but I'm only doing the 2l regular changes now because my fluid is still very new looking. Edited June 20, 2012 by fordy_alexsupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Iky Posted June 20, 2012 Share Posted June 20, 2012 You could probably take both hoses off the cooler and use one to suck new fluid in and let old one flow out the other. Might be harder to control this way and I'm not sure if it's a safe method but I've heard about somone doing it this way on here I'm sure. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Ah sounds like a good idea.. Iv sent a pm to keron if he has a method. Still I don't think a full flush is needed for my box atm Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 20, 2012 Share Posted June 20, 2012 The return is just that, a return to the gearbox sump, theres no suction there. Quote Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted June 20, 2012 Author Share Posted June 20, 2012 Not such a good idea then haha Quote Link to comment Share on other sites More sharing options...
Iky Posted June 20, 2012 Share Posted June 20, 2012 The return is just that, a return to the gearbox sump, theres no suction there. Ah, I get you. That idea's out then. I can't remember for the life in me where I read about it. Quote Link to comment Share on other sites More sharing options...
