Delboy52 Posted June 15, 2012 Share Posted June 15, 2012 Wondered if anyone has experienced these Hurricane headers? Link They are very similar to the Rush Imports which are currently unavailable. They are 4-2-1 collectors. Apparently this gives better low down torque. Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2012 Share Posted June 15, 2012 I'd think the main reason their made 4-2-1 is because their much easier to make Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 15, 2012 Share Posted June 15, 2012 They might also need to be jigged about a bit due to probably being designed for/on LHD models. Link to comment Share on other sites More sharing options...
Delboy52 Posted June 15, 2012 Author Share Posted June 15, 2012 Australians have RHD cars like we do. Many of the 1UZ aftermarket parts seem to be in Oz. I've not heard of the Hurricane brand before, but they seem to be the only off the shelf extractors left in the world. IMF 4-1 headers aren't available anymore and Neil at Rush has none left. Read some forum posts and they were claiming the 4-1 gave more power at the top end. They tend to be much shorter also. $695 aud, + shipping of about $300 aud, + import tax £?. So £650 to get them here plus whatever the tax is here. Still less than a quote I had for custom made ones. Anyone know a fabricator that could make some of these? Link to comment Share on other sites More sharing options...
Delboy52 Posted June 15, 2012 Author Share Posted June 15, 2012 Then I used a tax calculator.. Total customs value: £652.98 - Duty: £29.38 - VAT: £136.47 Total import duty & taxes due: £165.86 Total landed cost: £818.84 at AUD/GBP exchange rate of 0.6462 Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2012 Share Posted June 15, 2012 I doubt very much that you'd get them made cheaper here. Link to comment Share on other sites More sharing options...
ruishy1 Posted June 17, 2012 Share Posted June 17, 2012 i got a set of stainless manifolds made for a rover v8 in a sierra for 800 quid. but if your paying the same money better getting soemthing tried and tested. The 1uzfe is really starting to gain a fanbase as a cheap powerful engine. hopefully the aftermarket parts will start to come through Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 25, 2012 Share Posted June 25, 2012 Australians have RHD cars like we do. My mistake mate, I saw the dollar sign and assumed it was a U.S. based site. Link to comment Share on other sites More sharing options...
Delboy52 Posted June 25, 2012 Author Share Posted June 25, 2012 No worries mate. I managed to find some Rush headers kicking about in the UK so have those waiting to go on. May not be able to use the mid section of my Tanabe exhaust as the extractors reach back quite far though. Link to comment Share on other sites More sharing options...
Delboy52 Posted July 10, 2012 Author Share Posted July 10, 2012 I'm in the process of having the headers fitted along with a full Tanabe exhaust system and a custom Y pipe to connect it all up. I'm not sure if I should keep the mid box or not. The current system on the car drones like mad at 1500rpm and that is a straight through. Would it be too quiet with the mid and back boxes on though? This is a twin decat. If anyone knows what a Tanabe Medallion Touring exhaust sounds like, is it louder than stock? Link to comment Share on other sites More sharing options...
Guest ugp Posted July 10, 2012 Share Posted July 10, 2012 I ran a straight through 3" system with just a small back box, running custom headers too, it was very snap crackle and pop, no drone'ing though. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 10, 2012 Share Posted July 10, 2012 Just to give you a rough idea on what it could / might sound like. Link to comment Share on other sites More sharing options...
Delboy52 Posted July 10, 2012 Author Share Posted July 10, 2012 Mine has stock headers, with a small box on the back. Sounds quite different to yours though. The drone is inside when driving, don't really hear it from the outside. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 11, 2012 Share Posted July 11, 2012 What's the pipework like? I run 2x 2.5 downpipes into a single 3" under the transmission tunnel. Link to comment Share on other sites More sharing options...
Delboy52 Posted July 11, 2012 Author Share Posted July 11, 2012 rxv8 would know, he built it. I think it is 2X 2.5 decat pipes from the stock manifolds into a 2.5 Y-pipe, into what I think is a 3" mid and end pipe with a fairly small back box. Similar to the RSR style. Decided to keep the mid box. I listened to some samples of it on Scoobys and some Supras, and it sounds good still with the mid box in place. Idle is going to be quieter which suits me. I'd like to know what causes the drone because that's more the problem than the actual loudness, if you know what I mean. Imagine someone humming loudly in your ear up to about 1800rpm then it goes away and is replaced with the real V8 sounds. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 11, 2012 Share Posted July 11, 2012 rxv8 would know, he built it. I think it is 2X 2.5 decat pipes from the stock manifolds into a 2.5 Y-pipe, into what I think is a 3" mid and end pipe with a fairly small back box. Similar to the RSR style. Decided to keep the mid box. I listened to some samples of it on Scoobys and some Supras, and it sounds good still with the mid box in place. Idle is going to be quieter which suits me. I'd like to know what causes the drone because that's more the problem than the actual loudness, if you know what I mean. Imagine someone humming loudly in your ear up to about 1800rpm then it goes away and is replaced with the real V8 sounds. Usually when the cats are gutted? Have you got proper decat pipes on it, or were the old cats just bashed and emptied out? Link to comment Share on other sites More sharing options...
Delboy52 Posted July 11, 2012 Author Share Posted July 11, 2012 Can't be sure. I'm told they are decat pipes, I've not seen them myself. Old bashed out cats sounds like a dog rough thing to do. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 11, 2012 Share Posted July 11, 2012 True, it does happen though . Maybe get some pictures of you're current exhaust setup? Link to comment Share on other sites More sharing options...
Kirk Posted July 22, 2012 Share Posted July 22, 2012 Ah my old exhaust. I actually do miss it As for sound yes it was louder than stock but very tolerable with no drone on the cruise and a fantastic exhaust note. Id love to hear what it sounds like on a V8. Link to comment Share on other sites More sharing options...
Delboy52 Posted July 22, 2012 Author Share Posted July 22, 2012 Hey fella! I've had your Tanabe Touring Medallion exhaust in my garage since the London Motor Museum meet (which I didn't go to). It's only just been fitted to a custom Y pipe into Rush headers the last week or so. Here it is fitted and running. Link to comment Share on other sites More sharing options...
Kirk Posted July 23, 2012 Share Posted July 23, 2012 (edited) That sounds awesome. Very throaty Can only imagine what it sounds like at full chat. Hope your happy with it. Car looks brutal. Edited July 23, 2012 by Kirk (see edit history) Link to comment Share on other sites More sharing options...
