Replacing clutch - What else needs replaced in there?
Supe
Good morning everyone,
Going to take the gearbox out over the weekend for a clutch replacement, just wandering what else I should replace whilst it's in bits. (I've only got the pressure plate, clutch assembly and throwout bearing iirc).
Any other important parts, which should be replaced at the same time?
Finally got some time to work on the Supra and get it back on the road, the clutch went last year, so decided I would replace it myself but never got round to it due to work commitments and the weather being crap. Had access to other cars, so the Supra has just sat there looking sorry for itself :innocent:
Watching some of the recent Dragonball videos and Santapod drag videos, has really upset me :D Want to get back in mine asap :cool:
Thank you pedrosixfour, I will check the rear crank seal too.
Is it hard to replace this, any special tools needed to replace the crank seal? Also, do I need to by new bolts, or can they be re-used
p.s. just noticed the title doesn't make sense :p
Thanks zorglub :)
We got a price from the local Toyota garage... Rear crank seal £68+Vat, Flywheel bearing £72+Vat and Pilot bearing £55+Vat I think iirc
Sounds a bit high to me... is that the going rate for these parts?
Thanks
