add heywood Posted June 13, 2012 Share Posted June 13, 2012 Had a search but they were old posts. So my clutch is starting to slip in 5th gear pulls, biting point high on the pedal. I found out the clutch can be adjusted to get a bit more life from it but I basically think it can't take the power anymore (was running 550 fine, now at 700). The problem I might find is that it is an ORC clutch that has some sort of conversion from push to pull (or the other way round). If I get another clutch could this would have to be rectified. Ive also looked at replacing with another ORC but the high power application 709 series has been discontinued So what are my options guys need a clutch that will handle the power on the street. I very rarely drag the car, or even launch hard, mainly rolling pulls. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted June 13, 2012 Share Posted June 13, 2012 Everybody seems to like the RPS carbon Carbon setup Quote Link to comment Share on other sites More sharing options...
