Skimming!
FOSTA
Yes i was thinking the same after looking at yours a few times and comparing them to ones i've recently done, do
they need to be cut shorter ?
the two i've recently done haven't been cut down and i think this is half the problem you have.
They are both using the Greddy plenum, ones been welded on and the other bolted together
With the way he has made the plenum yeah they need to be shorter as it dosnt have much clearance on the strut tower!
But he didnt need to make the plenum as wide as he has, if he made it a few inches thinner then they wouldn't of been any need to make the runners shorter.
So it's just down to the way it's been made mate :)
I'm sure if you get a thick gasket for it and do it up super tight It will be ok?
All you doing then is overtightening the threads in the head and risking stripping them, then its head off
and get them helicoiled.
Fix it properly or you simply cause more grief for yourself further down the rd
My guess is, the runners havnt been cut evenly and when it's been welded its pulled it like that. Is it the end runners that's bent or is there a high spot in the middle.
Booooom! Got it bang on mate! It's the middle that has the high spot.
It's just it's resting on the right in the picture making it look like the left is off but it's both sides :)
Yeah I want it fixed right! It's not worth the hasstle! But I would like a thicker gasket if one is available pence it's refaced just to be sure.
I see, so the plenum needs reducing in size and a new set of runners welding or bolting
to it if you want a proper fix
Company: Motor Factors Ltd. Engine Services
Address:
Dunston Road
Dunston
Tyne & Wear
NE11 9EE
Contact: Mr. John Chapman
Telephone: 0191 460 5256 / 0774 896 0179
Email: engineservicesbtconnect.com
Profile: Engine Services NE11 9EE, Cylinder Boring and Resleeving, Submerged arc welding, Crankshaft Regrinding, Cylinder heads machined, Full engine rebuilds, Pressure test heads, Founded in 1958, staff with over 100 years of engine and cylinder head reconditioning expertise between them. Member of the Federation of Engine Re-manufacturers Ltd. Helicoil Timeserts fitted, all engine recon parts in stock. Japanese parts. Full in house machine shop facility.
Category: crank grinding
crankshafts
cylinder head specialist / modification
engine / engine specialists
engine / engineering
engine restoration / recondition
County scope: co. durham
cumbria
northumberland
tyne & wear
yorkshire
Cheers for that mate I'll give them a call in the morning ;)
Well yeah I sopose, or if I needed new runners I would think it would be fine cutting them shorter aslong as they clamp the flange down flat good and true. Well I say that but what do I know lol
To keep the runners from warping the way to go is reduce the plenum and leave the flanges
and web strengthening alone.
Wouldn't be to hard to modify the plenum :)
