Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 I just had the timing belt replaced on my 95 TT. The engine was like a mouse chewing paper before,but now there is a strange rattle on idle. It comes and goes on tick over, and sounds like the front top of the engine. Its quite a heavy insidious rattle noise-just can't put my finger or ear on it. Any ideas would be appreciated. In advance James Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2012 Share Posted June 9, 2012 did you change the tensioner at the same time? Quote Link to comment Share on other sites More sharing options...
Geo Posted June 9, 2012 Share Posted June 9, 2012 can you take a video of it? Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Yes tensioner kit was used. I will take a video of the engine and noise and post. Thanks for the help and replies James Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Can someone tell me how to post a short video? Thanks again for patience James Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 I am changing rattle to knock type noise......-:0 no rattle type knock? Haven't got a clue,the more i listen the more it sounds like the accessory tensioner,or a lifter? James Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2012 Share Posted June 9, 2012 persevere with trying to put up a video it'll give members a better idea Quote Link to comment Share on other sites More sharing options...
Geo Posted June 9, 2012 Share Posted June 9, 2012 copy past you tube link, then hit tab here(when your typing reply) ^^^ the little movie strip. paste into box, and submit post. Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Here it is, I think the noise can be heard quite clearly as the engine is otherwise like a mouse .... Link is uploading should be ready in about 15 Once again thanks for all the help James ttp://youtu.be/_nwQi1YSIxM Quote Link to comment Share on other sites More sharing options...
Geo Posted June 9, 2012 Share Posted June 9, 2012 Here it is, I think the noise can be heard quite clearly as the engine is otherwise like a mouse .... Link is uploading should be ready in about 15 Once again thanks for all the help James ttp://youtu.be/_nwQi1YSIxM try again mate, link is missing stuff Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Thanks Geo, had sussed it ! James Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Geo still being processed give it 15 mins Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 opps, can be heard at the start of this one but will post the better one,forget that too much wind noise Apologies James Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Think this one clear demonstrates the noise James Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 9, 2012 Share Posted June 9, 2012 bit of a strange one that, i would poss take the acc belt off and see if the noise goes Quote Link to comment Share on other sites More sharing options...
David P Posted June 9, 2012 Share Posted June 9, 2012 It sounds as though a component probably wasn't tightened up properly during re-assembly? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 9, 2012 Share Posted June 9, 2012 As above I think it could be the aux tensioner. Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 I had the AC gassed a week ago,it was like Alaska in the car, since T/B fitted no AC....coincidence? You can clearly hear the AC kick in but just ambient outside temperature- NO AC! So in short, nice AC and quiet engine before timing belt, not knock and no AC!!! Should have done it myself but just out of hospital. James Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 Is there adjustment in the Aux tens? James Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 9, 2012 Share Posted June 9, 2012 Its just a big spring, but the bearings in the pulley start to go. Take the aux off and run the engine, if the noise stops then its something in the aux belt run. Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 just unbolt it and run the engine? is that the tensioner with the bit angling upward to below the camshafts? Thanks very much for your imput James Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 9, 2012 Share Posted June 9, 2012 Take it youre not mechanically minded lol. Take it back to the place that did the belt and get them to do it. Quote Link to comment Share on other sites More sharing options...
Guest jamesgui Posted June 9, 2012 Share Posted June 9, 2012 They said it was my imagination , if its easy to take off, I can do it myself-just want to make sure I don't make any mistakes.... a few tips would be helpful.... james Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 9, 2012 Share Posted June 9, 2012 Excuse my poor editing of the photo but the aux tensioner and its pulley are arrowed in red, push the pulley in the direction of the blue arrow to take the tension off the belt then remove the belt highlighted in yellow Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted June 9, 2012 Share Posted June 9, 2012 Who fitted the belt? Quote Link to comment Share on other sites More sharing options...
