Parry_10 Posted June 8, 2012 Share Posted June 8, 2012 Just wondering how you are running your idle control valve? as you can bolt it up underneath but then you cant keep the check valve... so whats the best thing to do? im thinking of deleting mine all together and running a higher idle off the throttle butterfly stop Quote Link to comment Share on other sites More sharing options...
FOSTA Posted June 8, 2012 Share Posted June 8, 2012 I'm using a mkiii TT icv as the stock plug fits stright in, then drilling and tapping a fitting before the butterfly and running a hose from that stright to the mkiii icv. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 I'm using a mkiii TT icv as the stock plug fits stright in, then drilling and tapping a fitting before the butterfly and running a hose from that stright to the mkiii icv. yeh but how are you fitting the check valve? as it sits in the stock manifold but cant in an aftermarket one... maybe only TT has it Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 http://www.mkiv.com/techarticles/parts/iac/index.html Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 8, 2012 Share Posted June 8, 2012 The greddy manifold has a place for it, it runs off the back of the manifold. Lee has tucked mine out the way. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2012 Share Posted June 8, 2012 Mine is under the intake, Lee welded a plate on, you can run without one, i never had one on my red supra and it was never an issue. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 The greddy manifold has a place for it, it runs off the back of the manifold. Lee has tucked mine out the way. do you still run the stock icv rob and still have the check valve? there is a place underneath mine for it to bolt to but the check valve sits in the manifold so what I dont understand is what people do with the check valve as if you put it in it will just fall into the plenum... theres no where for it to sit Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 Mine is under the intake, Lee welded a plate on, you can run without one, i never had one on my red supra and it was never an issue. yeh there is a place under the intake for mine to bolt on to I just dont get how you can run the check valve part of it Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 8, 2012 Share Posted June 8, 2012 do you still run the stock icv rob and still have the check valve? there is a place underneath mine for it to bolt to but the check valve sits in the manifold so what I dont understand is what people do with the check valve as if you put it in it will just fall into the plenum... theres no where for it to sit Robs has an adapter plate that retains the check valve Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2012 Share Posted June 8, 2012 As far as i was aware mine is fitted as it would on a stock intake, just in a different place. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 8, 2012 Share Posted June 8, 2012 do you still run the stock icv rob and still have the check valve? there is a place underneath mine for it to bolt to but the check valve sits in the manifold so what I dont understand is what people do with the check valve as if you put it in it will just fall into the plenum... theres no where for it to sit yeah i run stock icv, lee fitted everything when the car was with him as i wanted it out the way. im sure there is a adaptor plate for it but dont hold me to that Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 Robs has an adapter plate that retains the check valve Thought so, so next question where can I get my hands on one of these adaptor plates? or will it make my life easier just doing away with the icv Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 8, 2012 Share Posted June 8, 2012 The Greddy manifold comes with pipework and said adapter plate. If you need just the adapter, i'm pretty sure we can supply them, PM Lee. As far as keeping it goes, it just makes life easier. Better starting and a more stable, lower idle is possible. Quote Link to comment Share on other sites More sharing options...
hodge Posted June 8, 2012 Share Posted June 8, 2012 Mine is also in place, if you leave it out you'll hate it trust me. Jevansio removed his for a while and the Idle was horrendous. Your cold start will be effected too. Don't do it. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 8, 2012 Share Posted June 8, 2012 The Greddy manifold comes with pipework and said adapter plate. If you need just the adapter, i'm pretty sure we can supply them, PM Lee. yeah Lee can get individual spares. i needed greddy intercooler pipe and he got that easy peesy Quote Link to comment Share on other sites More sharing options...
hodge Posted June 8, 2012 Share Posted June 8, 2012 What check valve are we talking about here, got a picture? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 8, 2012 Share Posted June 8, 2012 The stock one way valve in the standard TT intake manifold Hodgimus. It only allows air in, stops boost leaks from the ICV. Its a small reed/flap type valve that pushes into the manifold before the ICV is bolted on. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 What check valve are we talking about here, got a picture? yeh mate its in the link I posted if you look you can see on a stock intake the check valve and rubber gromit has a place to sit but in an aftermarket manifold its just a hole meaning no where for it to sit so I guess you need some sort of adaptor plate for every aftermarket intake if your going to run the icv Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 8, 2012 Share Posted June 8, 2012 yeh mate its in the link I posted if you look you can see on a stock intake the check valve and rubber gromit has a place to sit but in an aftermarket manifold its just a hole meaning no where for it to sit so I guess you need some sort of adaptor plate for every aftermarket intake if your going to run the icv Most manifold kits get everything included to do it.. get your card out and buy a greddy manifold! Quote Link to comment Share on other sites More sharing options...
hodge Posted June 8, 2012 Share Posted June 8, 2012 yeh mate its in the link I posted if you look you can see on a stock intake the check valve and rubber gromit has a place to sit but in an aftermarket manifold its just a hole meaning no where for it to sit so I guess you need some sort of adaptor plate for every aftermarket intake if your going to run the icv Ahhh aye, you can get away without using it, it doesn't effect it a great deal if I'm honest. Suprafans car doesn't or didn't have 1 fitted iirc and the idle was fine. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 Most manifold kits get everything included to do it.. get your card out and buy a greddy manifold! not a chance lol can get manifolds that do just as good a job for a lot cheaper;) Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 Ahhh aye, you can get away without using it, it doesn't effect it a great deal if I'm honest. Suprafans car doesn't or didn't have 1 fitted iirc and the idle was fine. are you saying you dont need to have the check valve? im sure you do.. ? Quote Link to comment Share on other sites More sharing options...
hodge Posted June 8, 2012 Share Posted June 8, 2012 are you saying you dont need to have the check valve? im sure you do.. ? I'm not saying that you don't need 1 I'm saying it will work ok without it. You best put your charcoal canister back in there too bud Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 8, 2012 Share Posted June 8, 2012 i'm not saying that you don't need 1 i'm saying it will work ok without it. You best put your charcoal canister back in there too bud Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted June 8, 2012 Author Share Posted June 8, 2012 I'm not saying that you don't need 1 I'm saying it will work ok without it. You best put your charcoal canister back in there too bud Ill put my charcoal canister back in if you put your abs pump back in Quote Link to comment Share on other sites More sharing options...
