Gauging interest on BBS LMs
Monkpower
Hello people I am at a stage where i'm considering changing my wheels.
I currently have genuine BBS LM alloys -
Front - 8J x 18 ET35 (235/40/18)
Rear - 9J x 18 ET 40 (245/40/18)
They were on the car when I bought it, there is kerbing and they could do with a bit of a refurb.
I'm after some wheels with a more aggressive offset and have my eye on a set.
I was just wondering what kind of money I would get for my wheels.
You can make the offset more aggressive on these without spacers ;)
Remove the spoke face from the rims, and re mount it on the rear. Improves the looks of the wheels and gains you a more aggressive offset for free :)
http://forums.rennlist.com/rennforums/993-forum/629628-bbs-lm-reverse-mounting-the-centers.html
Edited by j_jza80 (see edit history)
Surely this effects the clearance on the brakes...the fronts are et35 to start with and will be very close on UK spec brakes!?:confused:
If that works ok, that may be an option if they look ok on a Supra.
The front of the wheels where the bolts go is slightly curved, so I'm not sure it'd fit safely.
Clay I was looking at the rims that Chris had fitted to the supra he just sold, they look mean!! They won't break the bank either.
Two important factors - money and safety. I don't think getting a wider outer rim will be easy to find or indeed a viable option. I'm really curious to try the spoke face swapping reversing idea, but only if its a safe option with the correct torque settings, i've heard that once removed the little nuts shouldn't be reused.
