neil Posted June 4, 2012 Share Posted June 4, 2012 Hi people Will my supra still run if I put my Titan fuel rail with 850cc injectors with a fuel pressure regulator Don't want to go to the hassle if it's not goin to start as need to go tommy tuner wich is 3 mile down the road So will it run even if it's ruff ??? Thanks Neil Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 4, 2012 Share Posted June 4, 2012 I'll say probably not. Quote Link to comment Share on other sites More sharing options...
neil Posted June 4, 2012 Author Share Posted June 4, 2012 It's on a heltech sports ecu wich has a map on it But what to see if any body says it will run at all Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 4, 2012 Share Posted June 4, 2012 It *might* Not worth the risk though, such overfuelling could do massive damage to the engine, even in such a short distance. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 4, 2012 Share Posted June 4, 2012 dont do it bud. i near wrecd one of my first engine build attempts nwhen i was younger by running 500ccs on an ecu mapped for 220s. flooded , bore wash. ring damage . low compression. luckily for mke it was freshly honed so when 9i sorted it and run it in the comp came back up, buit it was never as good as it should have been Quote Link to comment Share on other sites More sharing options...
neil Posted June 4, 2012 Author Share Posted June 4, 2012 I have a fuel pressure regulator all the way down will this do any thing to help Quote Link to comment Share on other sites More sharing options...
neil Posted June 4, 2012 Author Share Posted June 4, 2012 Thanks for all the help people just gona let my tuner fit it all Neil Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 4, 2012 Share Posted June 4, 2012 again, it might, but why risk it? The likelihood of the fuelling being right is very slim, and you'll end up with just one of the things just listed if you're lucky, or all or more if you're not. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 4, 2012 Share Posted June 4, 2012 By the looks of it i think its best to leave it. Its not worth the risk for a 3 mile journey. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted June 5, 2012 Share Posted June 5, 2012 job for AA home recovery maybe?? Quote Link to comment Share on other sites More sharing options...
neil Posted June 5, 2012 Author Share Posted June 5, 2012 Thanks guys deffo goin to leave it Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted June 5, 2012 Share Posted June 5, 2012 Thanks guys deffo goin to leave it I didn't mean your going to need the AA btw, I just meant it might be worth using them to lift your car for you and deliver it to a 'garage of your choice' on a low loader AFTER you have changed the injectors. Quote Link to comment Share on other sites More sharing options...
neil Posted June 5, 2012 Author Share Posted June 5, 2012 I think I will just leave it as the tune is only on the 18th June but I'm gona have a long think about it by the way Can any body post a diagram of the fuel system at the front of the engine Thanks Luke neils son Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted June 5, 2012 Share Posted June 5, 2012 I hope I've posted this correctly Quote Link to comment Share on other sites More sharing options...
neil Posted June 5, 2012 Author Share Posted June 5, 2012 Thanks looks complex Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted June 5, 2012 Share Posted June 5, 2012 there's not that much to it really, I'm far from an expert and I've had mine off and put it back together and it hasn't caught fire once. Quote Link to comment Share on other sites More sharing options...
neil Posted June 5, 2012 Author Share Posted June 5, 2012 Yes if I wast just doin the fuel rail out and in But I'm putting a Titan fuel rail in with a regulator Luke And noing our look it will catch fire Quote Link to comment Share on other sites More sharing options...
