Gaz B Posted June 4, 2012 Share Posted June 4, 2012 Will 19 x 10 inch rota gtr white alloys fit on a 94 jap import mkiv supra? Link to comment Share on other sites More sharing options...
Colin-mkiv Posted June 4, 2012 Share Posted June 4, 2012 Offsets and tyre sizes? Link to comment Share on other sites More sharing options...
Ross C Posted June 4, 2012 Share Posted June 4, 2012 ^^ that. And is it on stock suspension or coilovers? Link to comment Share on other sites More sharing options...
marc_p Posted June 4, 2012 Share Posted June 4, 2012 No, black ones would of but unfortunaely the white only go on the 96/97's (unless it's a UK spec, in which case both white and black fit on 95+, but white only in 93/94). Link to comment Share on other sites More sharing options...
Gaz B Posted June 4, 2012 Author Share Posted June 4, 2012 stock suspension no coilovers, tyre sizes 235 possibly.... recommendation, any ideas for a 19" alloy? cheers Link to comment Share on other sites More sharing options...
SupraDan24 Posted June 4, 2012 Share Posted June 4, 2012 235's will be too small on 10j wheels, you should be looking at 265/275's. I assume you won't be 10j all round also? You need to post the offsets also. It might be easier to just post a link of the wheels in question. Link to comment Share on other sites More sharing options...
SupraDan24 Posted June 4, 2012 Share Posted June 4, 2012 No, black ones would of but unfortunaely the white only go on the 96/97's (unless it's a UK spec, in which case both white and black fit on 95+, but white only in 93/94). After reading the first post i was going to write that, then i read yours Link to comment Share on other sites More sharing options...
Gaz B Posted June 5, 2012 Author Share Posted June 5, 2012 http://www.performancealloys.com/wheel-details.aspx?ID=1697 Link to comment Share on other sites More sharing options...
qwarrior Posted June 6, 2012 Share Posted June 6, 2012 (edited) Rota GTR's are only available up to 9 or 9.5 if I'm not mistaken. You'll have to go with GTR-D to get 10inch. The offsets are ET +35 and will fit a stock arch just on the back with a 265. You may get some catching when going over speed humps with stuff in the boot. Pics of the same wheel in 18x10 with a 265. Also, you may want to give Paul Whiffin (Garage Whifbitz) a shout from the traders area. He did me a great deal on mine and he's an authorised trader on here. Edited June 6, 2012 by qwarrior (see edit history) Link to comment Share on other sites More sharing options...
