JMB Posted June 2, 2012 Share Posted June 2, 2012 Hi all, I did a lot of research about installing the BCC on my vvti TT. The DIY article I found isn t good as the non vvti ECU as no meaning with the vvti... Did someone succeed ? I read the disconnecting the map sensor is the solution Help please Quote Link to comment Share on other sites More sharing options...
JMB Posted June 4, 2012 Author Share Posted June 4, 2012 Ok, after lots of research, just plug the bcc to the map sensor (block e). I just don t know if I have to check the voltage, I ll look later Quote Link to comment Share on other sites More sharing options...
