boost controller
Jellybean
I have the avcr apexi , it runs off the vacuum pipe at the top of the intake , closest to the firewall
What is the vacuum pipe for , as it is just used for the defi and avcr feed , what was its orignal function ?
I am also having issues reading boost, i just noticed the y join has a brass restriction ring in the avcr feed but none in the defi feed, the defi reads 1 bar roughly and the avcr 0.24 ; i presume i need to remove the brass plug?
She did have a profec b greddy and was told they use them , else you get erratic boost
Got to the bottom of the issue incase anybody reads this, removed the brass restriction plug from the Y joint , got some new Vacuum hose and a new boost pressure air filter; all is running at 1.2 bar
But I would like to know the function of the Vacuum port it is running off on the Manifold, just the Defi and the boost controller runs off it ; should you still not retain its orginal OEM function?
