viper Posted June 3, 2012 Author Share Posted June 3, 2012 I test ran today at low speed in 5th gear and put foot to the floor and the boost reach about 15psi before i let off so im realy confused as im only getting 11psi showing every other time. Link to comment Share on other sites More sharing options...
Slicknick Posted June 3, 2012 Share Posted June 3, 2012 Wastegate sticking open? Link to comment Share on other sites More sharing options...
viper Posted June 4, 2012 Author Share Posted June 4, 2012 Surely if it was sticking open id get to much boost? Link to comment Share on other sites More sharing options...
Nic Posted June 4, 2012 Share Posted June 4, 2012 (edited) Surely if it was sticking open id get to much boost? No, the wastegate regulates the boost pressure, when it opens the exhaust gasses bypass the turbo. Edited June 4, 2012 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted June 4, 2012 Share Posted June 4, 2012 I test ran today at low speed in 5th gear and put foot to the floor and the boost reach about 15psi before i let off so im realy confused as im only getting 11psi showing every other time. The car will make more boost in higher gears when the engine is under more load. Link to comment Share on other sites More sharing options...
viper Posted June 6, 2012 Author Share Posted June 6, 2012 right chaps, thanks for all your in put. I removed the bov and ran the stock recirc valve and its boosting fine now. iv got myself a boost controller so i shall stick that in there and get it running to 1.2 bar as the restrictor plate is no longer in so have been extremely careful not to push it past 15psi just in case. boost leaks are an arse ake. Link to comment Share on other sites More sharing options...
ashbuster Posted June 6, 2012 Share Posted June 6, 2012 good news bud Link to comment Share on other sites More sharing options...
