BPU only reaching 11psi?
viper
If you've removed the restrictor ring and it's still only making 11psi with both cats removed then I'd suspect a boost leak somewhere, check all the vacuum, IC hoses and BOV.
http://www.mkivsupra.net/vbb/showthread.php?35924-Sequential-turbo-hoses&highlight=sequential
http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system&highlight=sequential
  • Replies 56
I don t think that modifying the exhaust increase the turbos psi ...
If you de-cat the exhaust it reduces back pressure to the turbos which causes the turbos to spool more aggresive and higher psi as a result.
Check for any boost leaks.
I ll Check, but what is strange is that I was already going to 11psi before modifying my exhaust...
Not sure of the make but i have 2.5inch first decat, 2.5 inch midpipe and 3inch 2nd decat and 3inch back from that. Before i went bpu i was getting 11psi nicely as expected from stock. But since going bpu its all over the place. I did a run yesterday flooring it in first and second and got 5psi down to 3psi in first and then 9 psi in second. Im geussing do to the boost fluturation iv got a leak somewhere. Im going to reattach the stock bov and block the blitz bov i have to first rule that out.
Do the above, if that doesn't make any difference then I'd check the condition of the turbo impeller wheels.
Guest George89
I had a similar problem last year. it ended up being my BOV leaking pretty badly (Blitz BOV)
Guest George89
no it won't effect boost pressure.
If you can take the BOV off put some water where the bov is ment too open and then blow hard through the vacuum hose that originally attaches to the intake manifold. Its a weird way to test but it worked for me. saw it bubbling so it wasn't sealing properly. Got a new dumb valve and was fine. (this aint a proper way to test but its free)
I got a tiptronic.
On "L" : reach 9 psi
On "2" : reach 11-12-11-12 (don t stop changing)
Same thing for "3"
What do you think ?
When I ll have Time, i ll Check all the hoses...
