viper Posted June 2, 2012 Share Posted June 2, 2012 Iv just apparently BPU'd my TT but its only reaching 11psi of boost. Iv fitted the uprated fuel pump, colder grade plugs, decats, restrictor ring. But havnt as yet fit the FCD. Please can you advise???? Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted June 2, 2012 Share Posted June 2, 2012 fit the fcd and go from there Quote Link to comment Share on other sites More sharing options...
safcdixon Posted June 2, 2012 Share Posted June 2, 2012 Surely he would know if he's hit fuel cut, apparently it's like hitting a wall, maybe you have a small boost leak? Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 2, 2012 Share Posted June 2, 2012 What size rr did you fit? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 2, 2012 Share Posted June 2, 2012 (edited) fuel cut on my scooby was nasty, it really did feel like hitting a wall is yours jap or uk? just wondering isnt 11psi still stock? 0.7bar i think 11 psi is or just over Edited June 2, 2012 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
Mario Posted June 2, 2012 Share Posted June 2, 2012 ^^yes 11 psi is about ,75 bar. Thought that boostcut occurs around @ 15-16 psi of boost. Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Yeah 11psi is stock, theres no fuel cut as not reaching 1bar boost. The RR looked like 2inch to 2.5 inch? Would nothqving the FCD fitted cause this? Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Mine is japspec Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Where is the MAP wire located for FCD installation? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 2, 2012 Share Posted June 2, 2012 is it pre vvti? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 2, 2012 Share Posted June 2, 2012 is it a hks fcd? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 2, 2012 Share Posted June 2, 2012 (edited) if it is follow this bud http://www.mkiv.com/techarticles/fcd/fcd.htm black goes to E on the diagram which is pin 69 = ecm ground red goes to b on the diagram which is pin 31 = efi main relay then cut the TURBO PRESSURE SIGNAL wire which is P on the diagram and its pin 62 wire the yellow to the wire closest to the ecu and wire the white to the other part of the wire you cut coming from the loom thats if its hks and if you have the same ecu as me ohh i forgot splice into the wires for the black and red but with the turbo pressure wire actually cut through it and wire one end to one colour and the other end to the other, as above Edited June 2, 2012 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Yes non vvti and yes hks fcd Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Ash buster thanks dude. Anyone have any idea why im only seeing 11psi? Quote Link to comment Share on other sites More sharing options...
Mario Posted June 2, 2012 Share Posted June 2, 2012 Which type of cat back exhaust are you running and what is the diameter of both decats, ie:2.5'' or 3'' decats? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 2, 2012 Share Posted June 2, 2012 anytime any probs just post up. as for the 11psi thats baffled me because i thought all jap specs overboosted when fully decatted thats the point in having the rr to lower the boost to a safe level, have you looked at your ecu yet to see if its a stock ecu? Quote Link to comment Share on other sites More sharing options...
shaky Posted June 2, 2012 Share Posted June 2, 2012 Open up your restrictor ring by 1mm then test it again or get a BOOST CONTROLLER, fit your fcd 1st. Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Fcd is fitted. Decat at front looked thin at about 2.5 inch rear is 3inch What setting does the fcd need to be on? Quote Link to comment Share on other sites More sharing options...
shaky Posted June 2, 2012 Share Posted June 2, 2012 Just had a look,, 9 is what they all say? Quote Link to comment Share on other sites More sharing options...
tony tt Posted June 2, 2012 Share Posted June 2, 2012 (edited) Have you tried to raise boost levels with a bc yet or have you just decatted with rr? some cars wont boost any higher than stock without fitting a boost controller to raise levels. have you tried an ecu reset then take the car a spirited run. Edited June 2, 2012 by tony tt (see edit history) Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 FCD fitted still stuck on 11psi, im gunna remove the restrictor ring and see if it makes a diffrence. Ecu is stock got the full tt conversion from kerion. Quote Link to comment Share on other sites More sharing options...
tony tt Posted June 2, 2012 Share Posted June 2, 2012 (edited) FCD fitted still stuck on 11psi, im gunna remove the restrictor ring and see if it makes a diffrence. Ecu is stock got the full tt conversion from kerion. The ecu will still need to relearn that the cats have been removed to be honest i wouldnt remove the restrictor ring. I would fit a boost controller and raise it accordingly till 1.2bar is reached. If it over boosts without the rr it can lead to failure. My ecu is also stock and its full bpu with no issues. Edited June 2, 2012 by tony tt (see edit history) Quote Link to comment Share on other sites More sharing options...
viper Posted June 2, 2012 Author Share Posted June 2, 2012 Restrictor ring removed same problem WTF Quote Link to comment Share on other sites More sharing options...
Littler Posted June 2, 2012 Share Posted June 2, 2012 Based on all the above I'd try to see if the boost controller successfully raises the boost to 1.2bar, if it does I'd say it was the size of your restrictor ring that is causing it to remain at stock level. Quote Link to comment Share on other sites More sharing options...
Littler Posted June 2, 2012 Share Posted June 2, 2012 Restrictor ring removed same problem WTF Ah maybe a leak then? Quote Link to comment Share on other sites More sharing options...
