HKS FCS to fit or not to fit?
viper
Hi,
Im sitting here looking for fitting instructions for my HKS FCD and have stumbled a cross all the cons of it. Im guessing fitting it is a bad idea, and i dont want to be running lean so can someone 1st tell me where the map wire is on the ecu and also what are the alternatives to the FCD to allow me to see 1.2bar? Iv got the decats, uprated fuel pump and colder grade plugs fitted so just need to fit this and im full BPU?
So help on the map wire location and identification of it and alternatives to the FCD?
Thanks
Hi,
Thanks
You got a restrictor ring in there?
You'll need something to stop/raise the fuel cut so you can run 1.2bar. Get a RR and open it up a bit. Mine's holding just under 1bar at WOT in 5th (on a warm day, I reckon it'll hit fuel cut on a cold day) and feels great :)
iv gone and fit the FCD and all seems fine.
i guess eventually ill fit an AFR gauge but im not doing anything where im perminatly stressing the engine, so im not overly worryed about going lean for a second here and there, i always run the highest octain fuel too so i hope that might assist a little and minimise det if any.
