barneybrendan Posted June 1, 2012 Share Posted June 1, 2012 i have just taken my ecu cover off to fit my hks fcd and noticed my ecu has a brass plaque stating its a mines ecu and has seals on the side of it.I have searched a bit and only found rescent references to na's fitting mines ecu's.What gains if any does this ecu give you. Just want to check that i can disconect the ecu to fit my fcd without causing it to have some sort of brain scramble and not work when reconnected. Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 1, 2012 Share Posted June 1, 2012 Result!!!! No idea about the other bits mind Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 1, 2012 Author Share Posted June 1, 2012 just been reading a thread on another forum.is it true these have no fuel/boost cut,which means i wont need the hs fcd. Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 1, 2012 Share Posted June 1, 2012 More of a result then! Where was it stamped? on the ecu case? Never seen a pic of one Quote Link to comment Share on other sites More sharing options...
Littler Posted June 1, 2012 Share Posted June 1, 2012 Found this and it says fuel cut is removed http://www.mkivsupra.net/vbb/showthread.php?252599-MINES-Ecu-for-auto-TT Quote Link to comment Share on other sites More sharing options...
safcdixon Posted June 1, 2012 Share Posted June 1, 2012 That's a great find, think il have a check under my carpet tomorrow Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 1, 2012 Author Share Posted June 1, 2012 thats the same plaque i have plus the seals onthe side .so fingers crossed i dont need my fcd.I have fitted the decats ,restrictor ring,walbro fuel pump,spark plugs.so i should be able to take the car out for a bit of fun then.I know the car isnt restricted and havnt seen anything wired in behind the dash anywhere. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted June 1, 2012 Share Posted June 1, 2012 Speed limiter is gone and it normally has upgraded fueling/timing map and from what I remember it definitely works as a fcd as I was having this discussion with Scott M and he and I both agreed that it seems a nice cheaper way to go about it for TT owners wanting to go BPU. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 1, 2012 Author Share Posted June 1, 2012 (edited) was a good find explains why the car was fairly quick for standard.Ive fitted bpu stuff now and im throwing error code 14.car wont rev past 2000.Its intermitten aswell.it did it once then went away when i stoped the engine.Gave it some welly up the motorway and it started again.i have to say when it ran good it went like hell.You can smell that its overfueling ,so im thining maybe plugs are crap or something to do with the coil packs now they have been disturbed. Edited June 1, 2012 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
Robzki Posted June 1, 2012 Share Posted June 1, 2012 I thought that some of these modded ecus are set to run at oem spec, ie no bpu as they are tuned for the stock boost and can play havoc if you try to do something different. I may have just dreamt it though Quote Link to comment Share on other sites More sharing options...
SPG Posted June 1, 2012 Share Posted June 1, 2012 I thought that some of these modded ecus are set to run at oem spec, ie no bpu as they are tuned for the stock boost and can play havoc if you try to do something different. I may have just dreamt it though My Mines came with a 1.2bar MAP Quote Link to comment Share on other sites More sharing options...
Robzki Posted June 1, 2012 Share Posted June 1, 2012 My Mines came with a 1.2bar MAP In that case I would email mines and give them the serial number etc and hopefully they can tell what has been modded on the ecu? Quote Link to comment Share on other sites More sharing options...
SPG Posted June 1, 2012 Share Posted June 1, 2012 In that case I would email mines and give them the serial number etc and hopefully they can tell what has been modded on the ecu? Yup, thats the best bet Quote Link to comment Share on other sites More sharing options...
Shane Posted June 2, 2012 Share Posted June 2, 2012 Barney, when I went BPU my car ran like a dog and wouldnt rev at all well under any sort of load and felt like a car with a set of dog HT leads if you know what I mean. It was the coil pack connectors. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 2, 2012 Author Share Posted June 2, 2012 Barney, when I went BPU my car ran like a dog and wouldnt rev at all well under any sort of load and felt like a car with a set of dog HT leads if you know what I mean. It was the coil pack connectors. thats exactly what its doing Shane.if i try to rev it it wont have none of it.Going to go check it now. Quote Link to comment Share on other sites More sharing options...
David P Posted June 2, 2012 Share Posted June 2, 2012 Info here. http://www.ebay.co.uk/itm/MINES-ECU-REMAPED-TOYOTA-SUPRA-2JZGTE-93-97-MK4-MKIV-AEM-EMS-POWER-FC-HKS-/270976944757?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f177c0a75#ht_1122wt_1037 Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 2, 2012 Author Share Posted June 2, 2012 Just took coil pack clips off.4 are new ,1 has no internal plastic .the other is crumbling away.Why would you just replace 4 of them,thats stupid. Quote Link to comment Share on other sites More sharing options...
David P Posted June 2, 2012 Share Posted June 2, 2012 Wise words from someone who is about to replace just 2 of them? Quote Link to comment Share on other sites More sharing options...
Noz Posted June 2, 2012 Share Posted June 2, 2012 Wise words from someone who is about to replace just 2 of them? Are you saying it would be best to replace 4 new ones? Quote Link to comment Share on other sites More sharing options...
David P Posted June 2, 2012 Share Posted June 2, 2012 Are you saying it would be best to replace 4 new ones? replace 4 of them,thats stupid. Quote Link to comment Share on other sites More sharing options...
Noz Posted June 2, 2012 Share Posted June 2, 2012 Replace 4 of them, 6 total. 4 new, 2 old? Quote Link to comment Share on other sites More sharing options...
SPG Posted June 2, 2012 Share Posted June 2, 2012 Maybe when the 4 were replaced, the remaining two looked new also. Replacing all 6 eliminates the the error of perception Quote Link to comment Share on other sites More sharing options...
David P Posted June 2, 2012 Share Posted June 2, 2012 Replace 4 of them, 6 total. 4 new, 2 old? I'm sure Old Wives say that one should be borrowed and the other blue. Quote Link to comment Share on other sites More sharing options...
David P Posted June 2, 2012 Share Posted June 2, 2012 (edited) Maybe when the 4 were replaced, the remaining two looked new also. Replacing all 6 eliminates the the error of perception 2 would get it going or 6 will keep it going. Edited June 2, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 2, 2012 Author Share Posted June 2, 2012 to clear this up 4 of them were replaced about a month or so before i got it making them less than 6 months old.i didnt say that i was only replacing 2 anywhere did i ,come on read properly. Quote Link to comment Share on other sites More sharing options...
