Bagci Posted June 1, 2012 Share Posted June 1, 2012 I have a Jspec TT and it's limited to 110 MpH, Instead of wiring up my current ecu in a way to remove the top speed limiter, could I buy an aftermarket ECU to plug in? If so what would be the best to buy and would it be hard to do...? I'm thinking of going BPU soon and the car is an automatic! Thanks. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 1, 2012 Share Posted June 1, 2012 surely its less hassle to just Spend £60 on a delimiter?? Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 1, 2012 Share Posted June 1, 2012 depends how rich you are really, if you have big plans then get a good ecu 2k so there you have it £60 or £2,000 Quote Link to comment Share on other sites More sharing options...
stevie_b Posted June 1, 2012 Share Posted June 1, 2012 Like the tubby one said. Fitting a different ECU is using an expensive sledgehammer to break a nut, if all you want to do is remove the speed limit. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 1, 2012 Share Posted June 1, 2012 Hold the phone people, get a Blitz, MINES Etc ECU, removes speed limiters, more powers and boost, about 300 quid Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 1, 2012 Share Posted June 1, 2012 remove trac fuse? cheapest way Quote Link to comment Share on other sites More sharing options...
johnny g Posted June 1, 2012 Share Posted June 1, 2012 Buy a single'd Supra ... Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 1, 2012 Share Posted June 1, 2012 remove trac fuse? cheapest way Interesting..... does this actually work? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 1, 2012 Share Posted June 1, 2012 i have a delimiter/converter fitted in my dash but if you remove the trac fuse it takes the limiter off Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 1, 2012 Share Posted June 1, 2012 i have a delimiter/converter fitted in my dash but if you remove the trac fuse it takes the limiter off nice Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 1, 2012 Share Posted June 1, 2012 heres a thread bud http://www.mkivsupra.net/vbb/showthread.php?131072-Removing-the-speed-liliter&highlight=remove+trac+fuse you loose the traction control but its useless anyway i had always been turning mine off Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted June 1, 2012 Share Posted June 1, 2012 (edited) I have a toms ECU for sale mate will do all you ask for and more won't fit your auto though Edited June 1, 2012 by bradleyh_15 (see edit history) Quote Link to comment Share on other sites More sharing options...
stevie_b Posted June 1, 2012 Share Posted June 1, 2012 remove trac fuse? cheapest way Surely this has side effects though...? I don't have a TT so I know very little about the trac fuse, but does it stop the traction control system from working? I accept that the stock traction control doesn't have a good reputation, but it's good to be aware of side effects. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 1, 2012 Share Posted June 1, 2012 yes mate you loose the traction control Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 1, 2012 Share Posted June 1, 2012 IF you have the money Syvecs ECU but your looking ££ Around £2500 fitted and mapped Quote Link to comment Share on other sites More sharing options...
Mugello Posted June 1, 2012 Share Posted June 1, 2012 Hold the phone people, get a Blitz, MINES Etc ECU, removes speed limiters, more powers and boost, about 300 quid This ! Or just delimit it for £60ish Quote Link to comment Share on other sites More sharing options...
SPG Posted June 1, 2012 Share Posted June 1, 2012 Mines ECU is the best ECU (plug and play) that i have used on my Auto-TT, and i have owned a TOMS,BLITZ and SARD. Send me £420 big ones and i will consider removing it from my car Quote Link to comment Share on other sites More sharing options...
