hodge Posted May 31, 2012 Share Posted May 31, 2012 (edited) Hi guys I've done a little video of both my bosch pumps running and every now and again the seem to change tone as if they lose power or something. Is this a normal for the noise of the pumps to change slightly. I think you can hear the tone change about 20 second or so into the vid, but watch it all and let me know what you think please. Cheers John Edited May 31, 2012 by hodge (see edit history) Quote Link to comment Share on other sites More sharing options...
hodge Posted May 31, 2012 Author Share Posted May 31, 2012 (edited) http://i1103.photobucket.com/albums/g470/Shineypics/ef10f2da.mp4 Edited May 31, 2012 by hodge (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 31, 2012 Share Posted May 31, 2012 Never noticed mine change in tone, will try and listen out for it next time im in the car. Have you just put it back together? maybe a bit of air in the lines pushing through? Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 31, 2012 Share Posted May 31, 2012 does it happen more if your low on fuel ? Quote Link to comment Share on other sites More sharing options...
hodge Posted May 31, 2012 Author Share Posted May 31, 2012 Never noticed mine change in tone, will try and listen out for it next time im in the car. Have you just put it back together? maybe a bit of air in the lines pushing through? It had been running about 10 mins before I took the vid so I'd have thought all the air would be out the tank breather by now. Do you know off hand what static fuel pressure your running Jamie? does it happen more if your low on fuel ? There's a half a tank in there rob. Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 31, 2012 Share Posted May 31, 2012 i know mine changes when i'm low on fuel and when its been running for a while. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 31, 2012 Author Share Posted May 31, 2012 i know mine changes when i'm low on fuel and when its been running for a while. How low on fuel do you mean? Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 31, 2012 Share Posted May 31, 2012 just when the light comes on mate,but i do notice it gets louder when its been running for a while Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 31, 2012 Share Posted May 31, 2012 It had been running about 10 mins before I took the vid so I'd have thought all the air would be out the tank breather by now. Do you know off hand what static fuel pressure your running Jamie? I think is 3bar, can check saturday when im out in it. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 31, 2012 Author Share Posted May 31, 2012 I think is 3bar, can check saturday when im out in it. That would be great bud, thanks just when the light comes on mate,but i do notice it gets louder when its been running for a while Think I might pull the hanger out of the tank n see if there's anything going on in there. Incase something's loose. Quote Link to comment Share on other sites More sharing options...
Biggenz Posted May 31, 2012 Share Posted May 31, 2012 You have nothing to worry about. Mine does the same and so does one of my mates'. For some reason some of the Bosch pumps are just noisier than others. I was also worried about this when I first installed mine, but I had stonking fuel pressure at the fuel rail and when the car was mapped, I always had more than enough fuel. I just live with it now. Quote Link to comment Share on other sites More sharing options...
Guest MikeyB571 Posted May 31, 2012 Share Posted May 31, 2012 I have twin external 044's with a swirl pot and mine change tone all the time. They are wired direct to the battery via a relay so it could just a variance in voltage. Quote Link to comment Share on other sites More sharing options...
hodge Posted June 1, 2012 Author Share Posted June 1, 2012 You have nothing to worry about. Mine does the same and so does one of my mates'. For some reason some of the Bosch pumps are just noisier than others. I was also worried about this when I first installed mine, but I had stonking fuel pressure at the fuel rail and when the car was mapped, I always had more than enough fuel. I just live with it now. I have twin external 044's with a swirl pot and mine change tone all the time. They are wired direct to the battery via a relay so it could just a variance in voltage. That's perfect, thanks guys. Quote Link to comment Share on other sites More sharing options...
