RobUK Posted May 30, 2012 Share Posted May 30, 2012 So as some of you know a week before dragonball my engine sounded like a bag of marbles, and we ended up going in the CRV. So come Saturday I am going to pull the engine and see what the damage is. Whilst the car is in bits I am going to do the following: Replace brake lines Replace fuel line Replace jspec brakes with UK Spec Do a Minor Engine Bay Tidy (not hodge style lol) Replace all engine gaskets Replace Buckets & Shims (had a noisy one) Retouch dash panels with original style flocking. Fit Electric Folding Mirrors (once sprayed) Remove Spare Wheel and fit a sub in the similar style of JamieP's Boot Install Remove Tinting from Door Windows Jeez looks like a bit of List and all I have managed so far is to remove the skirts in preparation for taking the car to the garage on Saturday Anything else to consider whilst doing this lot... As a certain supermarket says "every little helps" and before anyone suggests it, I am not considering going Single !! Cheers Rob Link to comment Share on other sites More sharing options...
Dim Sum Posted May 30, 2012 Share Posted May 30, 2012 what about the belts and crank pulleys? Engine skim? depends on your budget Link to comment Share on other sites More sharing options...
sideexitsupra Posted May 30, 2012 Share Posted May 30, 2012 Nail varnish remover will get the glue off the window after you remove the film. Tried everything else you can think of on my rear window before this wonder substance did the trick. Keep it away from the door cards though! Link to comment Share on other sites More sharing options...
RobUK Posted May 30, 2012 Author Share Posted May 30, 2012 what about the belts and crank pulleys? Engine skim? depends on your budget Belts are less than 1000 miles old, crank pulley might be an idea.... On the engine side I am going to see what the problem is first.... Might just buy a new short block from Mr T Link to comment Share on other sites More sharing options...
RobUK Posted May 30, 2012 Author Share Posted May 30, 2012 Nail varnish remover will get the glue off the window after you remove the film. Tried everything else you can think of on my rear window before this wonder substance did the trick. Keep it away from the door cards though! Nice Tip, cheers.... I'll probably remove the glass when I do it, to be safe Link to comment Share on other sites More sharing options...
Mugello Posted May 30, 2012 Share Posted May 30, 2012 Nail varnish remover will get the glue off the window after you remove the film. Tried everything else you can think of on my rear window before this wonder substance did the trick. Keep it away from the door cards though! True, i also used white spirit which worked a treat ! Also i recommend to remove the glass from the door, i did this and was SO much easier Nice Tip, cheers.... I'll probably remove the glass when I do it, to be safe This !! Can clean below the window seal line also Link to comment Share on other sites More sharing options...
RobUK Posted May 30, 2012 Author Share Posted May 30, 2012 Can clean below the window seal line also Clean! Jeez better give Havard a call Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 Started to strip the car down today, couple of random pics below, in my defence it was early Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 (edited) The first thing I did was remove the headlights and front bumper, I learnt a while ago that it's worth spending 20 mins removing it, rather than £££ respraying when you drop/spill something on it I then started to drain everything, oil, power steering fluid, coolant. This all gets recycled into a waste oil burner. Then connected the Air Conn System and set it to evacuate to clear down the AC system. Whilst the fluids drained I removed the exhaust, underbody bracing plates, covers etc, and then removed the prop shaft. Once all fluids where drained I then disconnected the radiator and inter cooler. Afterwards I removed the battery (already disconnected) battery tray, earth/neutral wire. I then started the pita job of removing the loom.... After completing this I decided I would call it a day... Next steps are to remove the gear box from the engine and then pull the engine out.. Edited June 2, 2012 by RobUK (see edit history) Link to comment Share on other sites More sharing options...
Mugello Posted June 2, 2012 Share Posted June 2, 2012 Looking good Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 Looking good Yeah just deciding what to do about the engine.... Hmmmm Link to comment Share on other sites More sharing options...
Littler Posted June 2, 2012 Share Posted June 2, 2012 Bit off topic but kind of glad you ended up going in the CRV to DB as there were a few times where I got separated from everyone at lights and leading a pack and then spotted your high up CRV with DB stickers, was a good marker Looks good for a non-project Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 Bit off topic but kind of glad you ended up going in the CRV to DB as there were a few times where I got separated from everyone at lights and leading a pack and then spotted your high up CRV with DB stickers, was a good marker Looks good for a non-project I was also making the effort to keep people together I am glad I went in the CRV, it only cost just over a tank and a half of fuel Not sure what will happen with this "project" in a way I am doing all the things I didn't have the time to do when I rebuilt the car 2 years ago. Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 2, 2012 Share Posted June 2, 2012 New Toyota block is a lot of work as you will still need to strip it, I would look at a second hand stock engine in good condition Look forward to watching this come together though, refresh is always fun Link to comment Share on other sites More sharing options...
sdistc Posted June 2, 2012 Share Posted June 2, 2012 What state are your coilpacks and loom connectors in? Might be a good opportunity to replace that with new OEM. Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 New Toyota block is a lot of work as you will still need to strip it, I would look at a second hand stock engine in good condition Look forward to watching this come together though, refresh is always fun I "thought" you could buy a complete short block from Toyota and bolt it straight on? Looking at various things I'll probably end up stripping it down and rebuilding the block... Suppose I'll see when I get the engine out if the car and strip it down... Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 What state are your coilpacks and loom connectors in? Might be a good opportunity to replace that with new OEM. Not looked at coil packs, but I am going to look at the loom generally, it has so many cuts into it for Apexi ITC, RLTC and Apexi SAFC that it was a pig to get out through the firewall... Link to comment Share on other sites More sharing options...
RobUK Posted June 2, 2012 Author Share Posted June 2, 2012 When removing the loom today I noticed that there is a spare connector which was originally connected to the Throttle Control, I have had a search but have been unable to find out how and if this can be removed.. Has anyone attempted this ? Link to comment Share on other sites More sharing options...
