attilauk Posted August 8, 2005 Share Posted August 8, 2005 you need to sort out the tramping or it will do it again. what is tramping? i've never heard the term before Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 8, 2005 Share Posted August 8, 2005 wheel hop mate. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 8, 2005 Share Posted August 8, 2005 Bad luck on the diff issue Rick. Serious spec you've got there, enjoy! Gaz. Quote Link to comment Share on other sites More sharing options...
attilauk Posted August 8, 2005 Share Posted August 8, 2005 wheel hop mate. Gotcha, cheers mate Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 8, 2005 Share Posted August 8, 2005 Yep, you have a super tramp problem mate, better fix it because having this car immobilised is the crime of the century http://images.amazon.com/images/G/covers/B/00/000/2GE/B000002GEV.l.gif Quote Link to comment Share on other sites More sharing options...
Guest Steve@EMS Posted August 9, 2005 Share Posted August 9, 2005 I think the diff is ok internally, but will know more tonight when we take it out. The diff cover is damaged but replaceable, but the mountings and rear prop will have to be replaced and the floor needs plating and welding up. Oh and the handbrake cables need replacing too, so not too much damage really. Hopefully we should have it ready for some testing in a couple of weeks, So will keep you guys posted on how it goes. Thanks for all the sympathy and support guys Regards Steve@EMS Quote Link to comment Share on other sites More sharing options...
Guest ricksupra Posted August 9, 2005 Share Posted August 9, 2005 We will fix the tramping, we were looking at using polyurethane (spelling not correct) for the diff mounts as they will give a little to no movement but should be up to the job. We are also going to balance prop shaft again, we are going to weld where the prop made 3 splits inside and underneath chassi, to make that stronger, you wouldnt believe how thin the metal is, and find a way to fix ballast down in boot, we have 100kg of iron weights at back, we are also going to look into launch control, bee r revlimiter but not ideal. all will be good, hopefully for a session in 2 weeks time at york raceway..........I will crack the 10's Quote Link to comment Share on other sites More sharing options...
