Guest suprasteven Posted May 27, 2012 Share Posted May 27, 2012 As the title says really i wanted to know which are the best filters as i am going to service the car in a month! K&N? Thanks Link to comment Share on other sites More sharing options...
stevie_b Posted May 27, 2012 Share Posted May 27, 2012 Stock ones! I wouldn't even bother with TRD ones unless you have a highly modified car. Link to comment Share on other sites More sharing options...
mr lover Posted May 27, 2012 Share Posted May 27, 2012 Toyota knew what they were doing mate Link to comment Share on other sites More sharing options...
Geo Posted May 27, 2012 Share Posted May 27, 2012 as above, stock ones. But you can go for the bigger lexus filter, holds a little more oil. Link to comment Share on other sites More sharing options...
Tyson Posted May 27, 2012 Share Posted May 27, 2012 I can't see anyone has mentioned it yet but I would stick with stock Link to comment Share on other sites More sharing options...
Guest suprasteven Posted May 27, 2012 Share Posted May 27, 2012 That was a great responce!! So just go direct to toyota?? Link to comment Share on other sites More sharing options...
Swampy442 Posted May 27, 2012 Share Posted May 27, 2012 Yep, straight to Toyota Or you could try Whifbitz as well. Link to comment Share on other sites More sharing options...
Graham1984 Posted May 27, 2012 Share Posted May 27, 2012 Opie oils also sell fuel filters ect too. Link to comment Share on other sites More sharing options...
Geo Posted May 27, 2012 Share Posted May 27, 2012 http://www.mkiv.com/techarticles/parts/toyota_filter/index.html Link to comment Share on other sites More sharing options...
Guest suprasteven Posted May 27, 2012 Share Posted May 27, 2012 Sweet!! thanks for that link Geo Does anyone have the part numbers for the Lexus v8 oil filter? i know its in the pics but thats from the states so might differ from UK Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2012 Share Posted May 27, 2012 Sweet!! thanks for that link Geo Does anyone have the part numbers for the Lexus v8 oil filter? i know its in the pics but thats from the states so might differ from UK I can't link as I'm on my phone, but look through my started threads as I started one about oil filters and I'm sure the part numbers are in there . I went for the stock filter. It's only about £10 from Toyota. Link to comment Share on other sites More sharing options...
ScottC Posted May 27, 2012 Share Posted May 27, 2012 as above, stock ones. But you can go for the bigger lexus filter, holds a little more oil. How does that help? Link to comment Share on other sites More sharing options...
ashbuster Posted May 27, 2012 Share Posted May 27, 2012 http://www.mkiv.com/techarticles/parts/toyota_filter/index.html i went with that filter too Link to comment Share on other sites More sharing options...
Geo Posted May 27, 2012 Share Posted May 27, 2012 Sweet!! thanks for that link Geo Does anyone have the part numbers for the Lexus v8 oil filter? i know its in the pics but thats from the states so might differ from UK same part number bud. How does that help? Using a bigger oil filter increases the volume of oil available to the engine and increases the filtration, i've always used larger oil filters on my Supra. i went with that filter too can i ask why bud? Link to comment Share on other sites More sharing options...
Kirk Posted May 27, 2012 Share Posted May 27, 2012 Opie oils also sell fuel filters ect too. I bought my last stock of MAHLE filters direct from Opie. Slightly cheaper than stock but probably end up costing you the same with postage. Link to comment Share on other sites More sharing options...
ashbuster Posted May 27, 2012 Share Posted May 27, 2012 can i ask why bud? someone told me to lol they said to either stick with stock or go with that one. Link to comment Share on other sites More sharing options...
Geo Posted May 27, 2012 Share Posted May 27, 2012 someone told me to lol Wasn't me was it, Link to comment Share on other sites More sharing options...
ashbuster Posted May 27, 2012 Share Posted May 27, 2012 lol im not too sure it works and i dont have a leak anymore. cost a tenner Link to comment Share on other sites More sharing options...
Guest suprasteven Posted May 27, 2012 Share Posted May 27, 2012 Wkd thanks Geo stock for the air filters too i take it?? i ve been told to go k&n for that!!?? Link to comment Share on other sites More sharing options...
Guest suprasteven Posted May 28, 2012 Share Posted May 28, 2012 ?? Link to comment Share on other sites More sharing options...
Geo Posted May 28, 2012 Share Posted May 28, 2012 stock filter or a K&N bud, it don't matter. Link to comment Share on other sites More sharing options...
stevie_b Posted May 28, 2012 Share Posted May 28, 2012 They most important thing with the air filter is to keep the stock feed and filter box, unless you know how to fit a decent cold air ducting system and heat barrier for an aftermarket non-panel filter. Again, unless you know why you need a K&N or whatever, then you probably don't need it. Too many people fit mushroom filters thinking they're better (usually becasue their mates told them that), but they usually result in less power due to the filter pulling in warm air from the engine bay. I don't trust anyone else more than Toyota to make a decent filter for a supra. I'm guessing they spent more on R&D to find the sweet spot on a Toyota 2JZ engine of non-restrictive flow vs effective filtration than K&N did. Lexus oil filters have been debated on here before, in particular in this thread: http://www.mkivsupra.net/vbb/showthread.php?260671-Oil-filter. Link to comment Share on other sites More sharing options...
Guest suprasteven Posted May 28, 2012 Share Posted May 28, 2012 Yes oil filters i am ok with all the help is greatly appreciated and i ll be going with the lexus v8 oil filter what i was confused on was the air filter as your right i ve heard its better with a mushroom and i did have one on my cupra which did make a difference i jus wanted to know if it was the same on the supra?? if the stock is better then i ll just replace the filter with a new one!!?? Link to comment Share on other sites More sharing options...
Josh Posted May 28, 2012 Share Posted May 28, 2012 Yes oil filters i am ok with all the help is greatly appreciated and i ll be going with the lexus v8 oil filter what i was confused on was the air filter as your right i ve heard its better with a mushroom and i did have one on my cupra which did make a difference i jus wanted to know if it was the same on the supra?? if the stock is better then i ll just replace the filter with a new one!!?? Stock airbox with a panel filter is much better than an aftermarket filter just in the engine bay (and cheaper, if you still have the stock setup), unless you make a cold air box and feed Link to comment Share on other sites More sharing options...
ubersonic Posted May 29, 2012 Share Posted May 29, 2012 i ve heard its better with a mushroom and i did have one on my cupra which did make a difference i jus wanted to know if it was the same on the supra?? if the stock is better then i ll just replace the filter with a new one!!?? Something that hasn't been mentioned yet is that the HKS mushroom filter is (usually) a 200mm round filter that's bent into the mushroom shape by the guard, which means that not only is it exposed to heat in the engine bay but it is actually smaller than the stock JZA80 panel filter area wise, this is probably why the 300ZX HKS kit uses two of them. Link to comment Share on other sites More sharing options...
