barneybrendan Posted May 26, 2012 Share Posted May 26, 2012 Just fitted a second hand hks bov ,i think its a copy but the bit it sits on is the supra specific 90 degree fitting.The problem is it isnt venting off,instead i am getting a chatter back through the k&n air filter.Does this mean the bov is knackerd and fit for the bin. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 26, 2012 Author Share Posted May 26, 2012 its the same unit as the one in the link http://www.ebay.co.uk/itm/HKS-BOV-SSQV-blow-off-180sx-240sx-S13-S14-S15-Sr20det-300ZX-Z32-VG30DETT-GC8-WRX-/390420871052?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae6e5b78c Quote Link to comment Share on other sites More sharing options...
Jimmy James Posted May 26, 2012 Share Posted May 26, 2012 I have a monza one you can try mate if yours isn't working, I'm down in plymouth next weekend if you want me to drop it off. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 26, 2012 Author Share Posted May 26, 2012 I have a monza one you can try mate if yours isn't working, I'm down in plymouth next weekend if you want me to drop it off. will get back to you on that mate Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted May 27, 2012 Share Posted May 27, 2012 A while back mine would sometimes get stuck open. Maybe its something similar? it was an easy fix, take apart the BOV with an allen key and check the valve bit itself, this is the black disk bit that connects with 5 legs to another disk behind it to make the seal. It had simply come unclipped on mine, bit of glue to make sure it didnt happen again and put it back together and no problems since. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 27, 2012 Author Share Posted May 27, 2012 A while back mine would sometimes get stuck open. Maybe its something similar? it was an easy fix, take apart the BOV with an allen key and check the valve bit itself, this is the black disk bit that connects with 5 legs to another disk behind it to make the seal. It had simply come unclipped on mine, bit of glue to make sure it didnt happen again and put it back together and no problems since. cheers will look at that today. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 27, 2012 Share Posted May 27, 2012 It might just be set too tight. There is an adjustment nut and bolt on the back of it, try moving that. I can't remember which way you have to turn it to make it open under lower pressure though Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 27, 2012 Author Share Posted May 27, 2012 ive had the bolt in and out with no differance Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted May 27, 2012 Share Posted May 27, 2012 I'm not sure if this makes a difference or not but are you trying to get it to vent when the car is stationary or moving. Mine is pretty quiet when stationary, its much louder when the car is moving and under load. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted May 27, 2012 Author Share Posted May 27, 2012 stationary.reving then letting off.it just vents off through the air filter and sounds like turbo chatter.Had another tt here aswell yesterday and his vents when revving and letting off quickly.Ive just took it apart and the alan key screws rounded off .2 of them had to be cut.So it has now found its new home (in the bin). Quote Link to comment Share on other sites More sharing options...
