mawby Posted May 26, 2012 Share Posted May 26, 2012 Mine leaks. A bit of research reveals that this cover doesn't have a gasket and that leaks are normally due to corrosion or damage when a muppet uses a jack on it incorrectly. Looking at the bottom shows the signs of said muppet damage. I also know you can use something like Loctite 5910 to create a gasket, but it's not something I've ever done before. Is it really as simple as undoing the bolts pictured, cleaning the cover, applying the sealent and reattaching the cover? Annoyingly the propshaft bearing also needs changing as that leaks slightly after a long drive, but for now I just need the cover leak fixing as that is leaking 24/7. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 26, 2012 Share Posted May 26, 2012 Yup its that simple, clean,mdegrease, apply sealant and 'wet assemble' If you had a sheet of cork lying about you could just as easily use that. Quote Link to comment Share on other sites More sharing options...
mawby Posted May 28, 2012 Author Share Posted May 28, 2012 Cheers for that. I might give it a go this weekend. Quote Link to comment Share on other sites More sharing options...
